- Thank you received: 2100
Compatibility with Lantek and other high-end software
- phillc54
3 years 2 months ago #279424
by phillc54
Replied by phillc54 on topic Compatibility with Lantek and other high-end software
The ARC_BLEND parameters that you are changing have nothin to do with G2/G3 arcs, they ar for look ahead trajectory planning.
There is a CENTER_ARC_RADIUS_TOLERANCE_MM here:
linuxcnc.org/docs/devel/html/config/ini-...sub:ini:sec:rs274ngc
I tried adjust this earlier with some gcode that you posted but it did not resolve the error.
forum.linuxcnc.org/plasmac/49697-compati...-end-software#276995
- santy
- Thank you received: 10
3 years 2 months ago #279427
by santy
Replied by santy on topic Compatibility with Lantek and other high-end software
just tried it. changed to 10 no luck
- phillc54
3 years 2 months ago - 3 years 2 months ago #279429
by phillc54
I converted the file from your earlier post so it would run on an AXIS sim and the same errors happen.
I also ran this file on an online gcode simulator ncviewer.com/ and it ran fine.
I think that I am unable to help any further. It may be worthwhile posting on the G&M Codes section of the forum.
G-code:
Error:
G-code:
Error:
Last edit: 3 years 2 months ago by phillc54. Reason: Because the forum editor is a POS
- Thank you received: 4153
3 years 2 months ago #279437
Replied by rodw on topic Compatibility with Lantek and other high-end software
Does by chance Lantec uses absolute coordinates and not relative on arcs?
- phillc54
3 years 2 months ago #279438
by phillc54
- santy
3 years 1 month ago #279939
by santy
Hello.
I am still having some errors.
Could you please send your filter? It seems to work without errors.
thank you
thank you
Time to create page: 0.496 seconds
