Updating to latest Version QTPlasmaC
- Clive S
- Thank you received: 486
I am on version QTplasmaC C221.153 linuxcnc V2.9.0 -pre 0-5518 – g8ae 2ceb6c
- phillc54
- Thank you received: 2100
- Thank you received: 4153
Theoretically you should be able to update to the latest and all "should" go well.
Don't forget that we don't provide any warranty.
If it fails, the way I did it in the past was to start afresh. I created a real rough config in pncconf and cut and paste in all the ini and hal settings into the file. This does not take very long and I got quite good at it in the early days!
- phillc54
- Clive S
phillc54 wrote:
If it fails then it would be best to report the failure so we could fix it.
OK I had another drive with a slightly older version but the same version of linuxcnc so I swapped it out in case it failed which it did.
I thought the warranty was about 10 years.Don't forget that we don't provide any warranty.
- Clive S
- phillc54
Was the apt error before the QtPlasmaC startup error?
If so it may pay to remove the linuxcnc-doc-en package and try sudo apt update, sudo apt dist-upgrade again before trying to run QtPlasmaC.
- phillc54
It shows as -y21.20, I think it should be y-21.20
- Clive S
Yes you are correct well spotted this is from the older version drive that I had.It looks like you have either LASER_OFFSET, CAMERA_OFFSET, or OFFSET_PROBING with an odd Y value.
It has now booted and looks ok. Is this the latest?
If so I will update with the drive I use. Thanks.
- phillc54
We will add a check for errors like that one.
