QTPlasmaC ARC_OK led not working
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
24 Aug 2023 13:50 #278859 by mariusl
QTPlasmaC ARC_OK led not working was created by mariusl
Hi
I testing all my input signals on a new installation by placing a shorting link on the inputs. I can see the ARC_OK input is working correctly but the ARC_OK LED on the main screen does not come on. I am using mode 2 at the moment. I have seen this on other working installations as well.
Is there a special way to set this up or how does it work?
Regards
Marius
www.bluearccnc.com
  • mariusl
  • Platinum Member
  • Platinum Member
24 Aug 2023 14:08 #278862 by mariusl
Replied by mariusl on topic QTPlasmaC ARC_OK led not working
Ok I think I have how it works. It looks like you have to pulse the torch or put it on before the LED is looked at
Regards
Marius
www.bluearccnc.com
24 Aug 2023 14:42 #278865 by tommylight
Replied by tommylight on topic QTPlasmaC ARC_OK led not working
Yes, that is it.
Not very convenient, but it has to be done only once so it is OK.
  • mariusl
  • Platinum Member
  • Platinum Member
24 Aug 2023 15:16 #278870 by mariusl
Sure that not a problem at all.
Every time I do a new installation I am more impressed by QTPlasmaC.
Regards
Marius
www.bluearccnc.com
The following user(s) said Thank You: tommylight, snowgoer540
Time to create page: 0.195 seconds
