Save Material Can't be changed
  • aabtech
  • aabtech's Avatar Topic Author
  • Premium Member
  • Premium Member
26 Aug 2023 02:31 - 26 Aug 2023 02:44 #278978 by aabtech
Save Material Can't be changed was created by aabtech
In the video you will see I have selected a 3mm saved material which have been saved in QtPlasmaC but when I select and save for cutting It select 3mm and when cutting it select Temporary which is gcode from SheetCAM I generated an come back to 3mm after cutting.
Last edit: 26 Aug 2023 02:44 by aabtech.
26 Aug 2023 02:35 - 26 Aug 2023 04:41 #278979 by phillc54
Replied by phillc54 on topic Save Material Can't be changed
I don't see a video...
There are a couple of odd things happening in the materials handling, we are currently working on it and should have it finished tomorrow.
Edit: Can you post the video so we can make sure your issue gets fixed with our changes.
Last edit: 26 Aug 2023 04:41 by phillc54. Reason: Video appeared.
26 Aug 2023 04:40 #278985 by phillc54
That is fixed in the changes that we are testing.
27 Aug 2023 02:23 #279058 by phillc54
The changes have been pushed.
  • aabtech
  • Premium Member
  • Premium Member
27 Aug 2023 06:13 #279074 by aabtech
Replied by aabtech on topic Save Material Can't be changed
I have updated linuxcnc but still the
Same problem
27 Aug 2023 06:50 #279077 by phillc54
Has the buildbot you updated from finished building or are you using a RIP installation.
  • aabtech
  • Premium Member
  • Premium Member
27 Aug 2023 08:25 #279079 by aabtech
Am using Debian 12 buildbot2.
It has finished building but still no change.
27 Aug 2023 11:12 #279087 by snowgoer540
Replied by snowgoer540 on topic Save Material Can't be changed
What version does it say in the window title?
  • aabtech
  • Premium Member
  • Premium Member
27 Aug 2023 18:16 #279100 by aabtech
27 Aug 2023 18:19 #279102 by snowgoer540
Latest version is v1.236.288
Buildbot might not be done, or is hung up.
Time to create page: 0.143 seconds
