Small scale adjustment
- LucasWorx
- Thank you received: 6
20 Sep 2023 14:37 #281222
by LucasWorx
Small scale adjustment was created by LucasWorx
Hey guys. I need to adjust the scale of my X and Y axis by a few mm's. I have tried changing the scale parameter in the .ini file and saving it but it still cuts the exact same dimensions as before the change. Even after closing and restarting QTPlasmaC, the change does not take effect. Is there somewhere else I should be making the change?
- Thank you received: 7496
20 Sep 2023 15:44 #281230
Replied by tommylight on topic Small scale adjustment
That sounds like you are editing a different file, so first make sure of that.
Happens often to me as i have several configs on the same PC.
- LucasWorx
20 Sep 2023 18:27 - 20 Sep 2023 18:42 #281245
by LucasWorx
Replied by LucasWorx on topic Small scale adjustment
Ok, I do have a couple configs so I'll double check and post back. Thanks.
Last edit: 20 Sep 2023 18:42 by LucasWorx.
- LucasWorx
20 Sep 2023 20:17 #281252
by LucasWorx
Ok, I guess when I originally configured the machine, I had saved the newer config file as the same name or close to it and pasted it on the desktop so that's the one I was editing instead of the one I needed to edit. All good now. Thanks!
Time to create page: 0.407 seconds
