What type of laser to use
- mariusl
03 Oct 2023 16:13 - 03 Oct 2023 16:17 #282171
by mariusl
Regards
Marius
www.bluearccnc.com
What type of laser to use was created by mariusl
Hi
I want to add a laser to my machine to enable me to line up at odd locations. I have been searching to find something suitable but have not found anything.
What does the plasma Gurus use?
Regards
Marius
www.bluearccnc.com
Last edit: 03 Oct 2023 16:17 by mariusl.
- Thank you received: 7496
03 Oct 2023 17:31 #282179
Replied by tommylight on topic What type of laser to use
The cheapest laser pointer with cross.
That is the only thing i can find here, and last two came with a single line and a fuzzy mess!
- mariusl
03 Oct 2023 17:52 #282182
by mariusl
Regards
Marius
www.bluearccnc.com
Replied by mariusl on topic What type of laser to use
I found some line lasers from a Hobby Shop over here. Small 12mm tube like modules. I am going to put them in a 3D printed housing of sorts and see how it works.
Regards
Marius
www.bluearccnc.com
03 Oct 2023 21:01 #282205
Pretty sure i have the same ones, they do come with "cross" lens, see if they have those, much easier to deal with one.
I threw a dead one (full of water) a while back, now i regret that as i could have used one with funny lenses.
Advice to self, if you ever throw them, keep the lens!
- Thank you received: 4153
03 Oct 2023 21:37 #282214
Replied by rodw on topic What type of laser to use
I used something like this www.aliexpress.com/item/1005005497606307.html
As I had 24V on the gantry, I used a small 24v to 5v converter to power it
www.ebay.com.au/itm/125306534110
- Deveraux
- Thank you received: 8
16 Oct 2023 17:08 - 16 Oct 2023 17:10 #283133
by Deveraux
Replied by Deveraux on topic What type of laser to use
I did not use a cross laser but two Line Lasers, which cost me 4 Euro a Piece from amazon. Mounted them via a 3d Printed part to form a cross which is always perfectly centered no matter which hight the z axis is i found it easier than to align a cross laser module since it is height independent no matter the position of the z axis or material thickness .
Last edit: 16 Oct 2023 17:10 by Deveraux.
- bkt
- Thank you received: 114
19 Oct 2023 21:39 #283323
by bkt
Replied by bkt on topic What type of laser to use
these is an good coverter .... use many time.As I had 24V on the gantry, I used a small 24v to 5v converter to power it
Time to create page: 1.529 seconds
