Run From Line bug
- caretech
- Thank you received: 26
16 Oct 2023 23:32 #283144
by caretech
Run From Line bug was created by caretech
I support another user's table & software, and recently updated LinuxCNC for him so we could take advantage of the fix to material handling as described in
this post
. Now the material selection works as expected when using Conversational or Single Cut, but it seems a Run From Line bug related to material has been introduced.
Behavior observed: when trying to Run From Line, the material that is set in the ngc file is ignored, and QtPlasmaC reverts to the default material. If Cycle Start is pressed, an error pops up: "Operator Error: Materials Error: Material #1000000 is not in the materials list." The gantry moves to the correct XY coordinates and follows the cut path, but the torch does not come down and probe, and of course the torch is not fired.
Run from line used to work great before the update.
QtPlasmaC version: 1.236.290
LinuxCNC version: 2.10.0-pre0-2069-g9de3c86d4
- phillc54
- Thank you received: 2100
17 Oct 2023 04:48 #283157
by phillc54
Replied by phillc54 on topic Run From Line bug
Oops, sorry about that. A fix has been pushed, thanks for the report.
The following user(s) said Thank You: caretech
- Thank you received: 4153
17 Oct 2023 05:46 #283160
Andy last night was building installers for the final release...
Replied by rodw on topic Run From Line bug
Is 2.9 still accepting commits?Oops, sorry about that. A fix has been pushed, thanks for the report.
- phillc54
17 Oct 2023 05:57 #283161
by phillc54
AFAIK bug fixes are OK.
- caretech
17 Oct 2023 09:28 #283165
by caretech
Replied by caretech on topic Run From Line bug
Thanks so much for the quick fix, phillc!
- caretech
17 Oct 2023 13:59 #283182
by caretech
I pulled source and built, and installed on the machine. Run from line works, thanks again! We depend on this functionality in production quite a bit. Just one little observation / nitpick -- the G-code is now uppercase when a file is loaded, which is nice. (I support this change) However, when in RFL mode, the g-code reverts to lowercase. Clicking Reload to exit RFL results in uppercase code again.
- phillc54
18 Oct 2023 05:26 #283206
by phillc54
Hopefully that should be Ok now as well.
- caretech
31 Oct 2023 12:33 - 31 Oct 2023 12:34 #284177
by caretech
Gcode now stays caps in RFL, thanks. I think I may have uncovered another material handling issue related to conversational last evening. I had 4 parts to cut and was able to fit them on to a scrap piece of material, but only if I cut two at a time at a different place and rotation on the remnant piece. These are the steps I took:
1. Load g-code file, nest of 2 parts (normal post from SheetCAM)
2. Cut the parts -- all is well so far
3. Used Conversational to rotate my nest 90 degrees
4. Tried to set machine X/Y zero at another spot on the scrap I was cutting from
This resulted in the same "material #10000000 is not in the materials list" error. I hit Retry and the error went away, but after this I wasn't able to get the table to respond properly until I closed LinuxCNC and re-started. I ended up doing a new nest in Sheetcam at 90 degrees to the first one and using a fresh gcode file instead.
Last edit: 31 Oct 2023 12:34 by caretech. Reason: tweak error message for accuracy
- phillc54
01 Nov 2023 00:39 #284231
by phillc54
A fix has been pushed, also negative pierce offsets have been added.
The following user(s) said Thank You: snowgoer540, caretech, cutnweld
Time to create page: 0.687 seconds
