Cut speed and height calibration file
  • Joco
  • Joco's Avatar Topic Author
  • Platinum Member
  • Platinum Member
30 Oct 2023 00:09 - 30 Oct 2023 00:13 #284090 by Joco
I have been working on a cut height and speed calibration file which may be of interest.  Thought it might be worth sharing.
github.com/joco-nz/plasma_cut_calibration
There is an included M word that allows the file to do calibration runs on cut height as well as the normal speed.
The file also cuts out the resulting test with a chamfered corner to mark where Cut #1 started.
Cheers.
Last edit: 30 Oct 2023 00:13 by Joco. Reason: typo
The following user(s) said Thank You: phillc54, tommylight, rodw
  • Joco
  • Platinum Member
  • Platinum Member
07 Nov 2023 20:38 #284818 by Joco
Replied by Joco on topic Cut speed and height calibration file
I have added in an angle/curves test file.  Note that if you have high accelerations (>1000mm/s/s) without having a lot of rigidity it will expose all the jerk/wobble in your system.
Cheers - J.
Time to create page: 0.235 seconds
