QTPlasmaC can't find Python3-serial
- Thank you received: 7496
03 Nov 2023 16:58 #284479
Replied by tommylight on topic QTPlasmaC can't find Python3-serial
I did start with "try this"
BRLTTY is used for braille keyboards so takes priority over anything else, found this out the hard way a while back where USB stuff using serial would work on some PC's and laptops, but will not work no matter what i do with permissions and groups and dialouts on some other PC's and laptops. Removed that and everything worked. Took about 2 hours of searching as the whole f@kin internet is copy/paste the same "add user to group" and "chmod a+x ttyACM0" ! Where the hell did they get ACM0? I have never ever seen that on my equipment, and i do have a lot of equipment, a lot!
I need help...
I need help...
- snowgoer540
- Thank you received: 907
03 Nov 2023 17:04 #284480
by snowgoer540
Replied by snowgoer540 on topic QTPlasmaC can't find Python3-serial
Just wanted to make sure he tried it second
No doubt computers are simultaneously the solution for a myriad of problems and also the cause of a myriad of problems.
Hope all is well (or as well as it can be) in your part of the world!
03 Nov 2023 17:32 #284486
End rant.
My family, friends, neighbors are all good, so yes it is, some occasional s#it at the north side, luckily last time they f@ked up badly as they were planning a full on invasion on that side, we lost 1 but the world found out they are the problem. Was not enough they started 4 f@kin wars here to figure that out.
End rant.
- snowgoer540
03 Nov 2023 18:29 #284492
by snowgoer540
I'm glad to hear that!
I sure hope the world figures itself out soon!!
- donell
- Thank you received: 4
04 Nov 2023 09:54 #284514
by donell
Replied by donell on topic QTPlasmaC can't find Python3-serial
snowgoer540,
This is a package install.
None of those terminal commands produced any errors.
- donell
04 Nov 2023 10:00 #284515
by donell
tommylight,
Thanks for the suggestion.
Tried what you suggested. It would appear that brltty is not installed on my machine.
It is worth noting that the pmx485-test works fine so it would appear that the serial interface is operating properly.
Don
Don
- snowgoer540
04 Nov 2023 16:09 #284542
by snowgoer540
I found the error that is causing the failure within the try/except. Because of the line it breaks on, I am guessing that your Port name is incorrect.
I pushed a fix for the aforementioned error. It will likely reveal that whatever you put for the port is not found. Unsure what you put, but it may be an issue with a leading or trailing / , etc.
After the buildbot does its thing you can update to grab the changes. For 2.10, the version will be v1.237.302
- donell
04 Nov 2023 16:29 #284543
by donell
snowgoer540,
Genius!
The port name was indeed incorrect:
/dev/ttyusb0
instead of
/dev/ttyUSB0
It now works fine and talks to the Hypertherm OK.
Many thanks for your help and to the others that have replied to this topic.
Don
Genius!
/dev/ttyusb0
instead of
/dev/ttyUSB0
Don
The following user(s) said Thank You: tommylight, snowgoer540
Time to create page: 0.622 seconds
