Can you run Plasmac offline
2 years 11 months ago #286672 by ashesman
Is it possible to open Plasmac without Ethernet (Mesa 7i76e) connected?  I would like to be able to open Plasmac without being down in the shed with the machine.
It just crashes with a big messy warning that somewhere in there says 'network unreachable'.  Actually that is a gripe for me!  If my machine is not powered up rather than just a nice message 'cannot communicate', it just dumps a big mess on the screen that you have to scroll through too see what is going on.  Seems like a pretty common error that could justify a nice descriptive warning.  Or even wait for the machine to bee turned on, then carry on.  Just saying...
2 years 11 months ago #286692 by aleksamc
You should create some "simulating" configuration that doesn't include any external hardware. After this you can work with this simulation environment
2 years 11 months ago #286694 by rodw
Replied by rodw on topic Can you run Plasmac offline
Short answer no. You cannot open a gui if the mesa device is not found.
There is a QTplasmac simulation available in your control panel.
2 years 11 months ago #286698 by tommylight
Edit the attached file to match the IP address and the folder where your config is, make it executable and put it in the startup applications menu.
2 years 10 months ago #287612 by ashesman
Thanks everybody for your replies.  I will use one of those options to set it up so I can open PlasmaC without being at the machine.
2 years 10 months ago #287688 by rodw
The workflow I used was to map a file share to the machine and save my cut file direct from the postprocessor (sheetcam) into the nc_files folder
then visit the machine and hit the load latest button(check the docs on this.)
I was not keen on starting a cut without being at the machine
Time to create page: 0.366 seconds
