Having problems with my THCAD-10
- aabtech
- Thank you received: 16
02 Dec 2023 15:58 - 03 Dec 2023 00:26 #287029
by aabtech
Hi, I have a new plasma machine which I bought recently that has CNC ports and has 1:1 ratio divider and am using 1M ohms at each leg of + and - of the plasma machine which will give you 21:1 ratio but the THC doesn't move up and down but I can see the THCAD-10 LED light blinking fast when cutting and blink slowly when not cutting. i have attach my logs.
Having problems with my THCAD-10 was created by aabtech
Last edit: 03 Dec 2023 00:26 by aabtech.
- Thank you received: 7496
02 Dec 2023 18:09 #287037
Replied by tommylight on topic Having problems with my THCAD-10
Screenshot when cutting, not cutting, and settings page
- Thank you received: 4153
02 Dec 2023 19:14 #287045
Replied by rodw on topic Having problems with my THCAD-10
the light on the board shows your wiring to the thcad is correct.
Next step is to confirm that it is being read correctly by the mesa encoder.
open halshow and find the encoder you are using. Does the velocity pin ove at all or does it stay static.
If its static, then this is probably missing from your hal file.I thought it was added by pncconf
setp hm2_7i76e.0.encoder.00.counter-mode 1
setp hm2_7i76e.0.encoder.00.filter 1
setp hm2_7i76e.0.encoder.00.scale -1Please Log in or Create an account to join the conversation.
02 Dec 2023 19:15 #287046
Once your encoder velocity is responding correctly,
enter your thcad calibration data into the qtplasmac gui as per the instructions.
- aabtech
02 Dec 2023 23:56 - 03 Dec 2023 00:21 #287052
by aabtech
Replied by aabtech on topic Having problems with my THCAD-10
# ---ARC VOLTAGE ENCODER---
net plasmac:arc-voltage-in <= [HMOT](CARD0).encoder.00.velocity
setp [HMOT](CARD0).encoder.00.counter-mode 1
setp [HMOT](CARD0).encoder.00.filter 1
setp [HMOT](CARD0).encoder.00.scale -1
this is how it look like in hal. my board is 7i96s
Last edit: 03 Dec 2023 00:21 by aabtech.
- aabtech
02 Dec 2023 23:59 #287053
by aabtech
- aabtech
03 Dec 2023 00:46 - 03 Dec 2023 06:04 #287054
by aabtech
Last edit: 03 Dec 2023 06:04 by aabtech.
03 Dec 2023 11:58 #287085
Wrong polarity on THCAD input, or wiring not correct from THCAD to Mesa 7i96S.
Open the "halshow" and check if the encoder is counting correctly.
03 Dec 2023 20:45 #287139
THis is the step I told you to do earlier but you didn'tOpen the "halshow" and check if the encoder is counting correctly.
03 Dec 2023 21:58 - 03 Dec 2023 21:59 #287143
Yes you did Rod, i just reminded him.
Last edit: 03 Dec 2023 21:59 by tommylight. Reason: tags
Time to create page: 0.425 seconds
