Building 8 x 20 ft CNC machine
2 years 10 months ago - 2 years 10 months ago #288322 by aabtech
Hi, am planning to build a 8 x 20 ft CNC machine using  servo motor. using 1 KW AC servo motor and 750W with the rated speed is 3000/ 6000 .1KW for X & Y and 750 for Z. I want to know if the AC servo motor can handle it and what type of mesa board to use and how to set the encoder to mesa board.
Last edit: 2 years 10 months ago by aabtech.
2 years 10 months ago #288340 by tommylight
2 years 10 months ago #288346 by aabtech
Yes, and the type of Mesa board to use again can the AC servo motor 1kw rated speed of 3000/5000 handle that 8 X 20 feet CNC table.
2 years 10 months ago #288350 by tommylight
1KW is to much for any plasma, 400W will do just fine as you do need reduction.
An old Messer industrial plasma with 400KG gantry uses 2 of 500W motors with reduction.
Pinout of the control cable?
We can not advise you on the board without knowing if the drives have encoder outputs.
If the drive has encoder outputs, Mesa 7i95T has step/dir outputs and encoders inputs, so everything you might need.
2 years 10 months ago #288356 by aabtech
The driver has an encoder output. And what will the ratio of the motor reduction be is planetary gear reducer ok?
2 years 10 months ago #288358 by tommylight
Yes it is, but beware of the cheap ones, those have a lot of backlash.
If you can not find Mesa 7i95T, you can also get a Mesa 7i96S and 7i85 or 7i85S.
Time to create page: 0.162 seconds
