Building 8 x 20 ft CNC machine
2 years 10 months ago #288363 by RDA
Replied by RDA on topic Building 8 x 20 ft CNC machine
Yes, and the type of Mesa board to use again can the AC servo motor 1kw rated speed of 3000/5000 handle that 8 X 20 feet CNC table.
Its not about size, its about weight. You typically have some base ”variables” that somewhat define your setup:
- Mass to be moved
- Max speed to be achieved
- Max acc to be used
Then you roughly find your motor/gearbox/pinion combination. You would want to make sure the torque is enough to get your acc, rpm is enough to get to the speed you want and that the inertia ratio doesnt get too big.
Then just check your gearboxes can handle the speed and torque, then see what the total backlash is and is it inside your specs.
This is a pretty crude/simple approach but should get the sizing to ball park and keep cost/performance in a good level.
The following user(s) said Thank You: aabtech
Time to create page: 0.044 seconds
