THCAD-10 for Ohmic Sensing
15 Jan 2024 00:39 #290724 by CFE
THCAD-10 for Ohmic Sensing was created by CFE
Hi all,
We are looking at adding ohmic sensing to our plasma table. The plasma cutting primer shows the use of a THCAD-5, but is it possible to use a THCAD-10 (we have a spare one of them as we build our controller with a THCAD-10) ?
Cheers, Peter
P.S. By the way, our plasma table with QtPlasmaC works well, cuts everything from 1.6mm to 25mm or thicker with a Hypertherm 125. Haven't had any major hiccups for a long time, except for the computer getting a bit tired !
15 Jan 2024 02:52 #290726 by tommylight
Replied by tommylight on topic THCAD-10 for Ohmic Sensing
Yes, you can use THCAD10 instead of THCAD5, just set the scaling and offsets correctly for it.
15 Jan 2024 03:20 #290727 by CFE
Replied by CFE on topic THCAD-10 for Ohmic Sensing
Thanks Tommy !
16 Jan 2024 09:55 #290849 by rodw
Replied by rodw on topic THCAD-10 for Ohmic Sensing
Set your scaling so that 24 volts is a bit under 10 volts eg. say 9.5 volts. That way the component will know that 24v or greater is actually the torch cutting (that will do no harm)
Time to create page: 0.516 seconds
