Plasmac hal output link
- greekart
- Thank you received: 3
28 Jan 2024 13:38 #291804
by greekart
Plasmac hal output link was created by greekart
Hello everybody,
I try to set a panel for my plasma, i have linuxcnc 2.9.2 with qtplasmac gui.
I want external led when the program running/pause e.t.c.
Withi get that the pin is already linked from plasmac, i find than i need to unlink and link again the pins. Is that right?
Thanks a lot Panos
With
net machine-is-running hm2_7i96s.0.7i73.0.0.output-13 <= plasmac.program-is-runningThanks a lot Panos
- Thank you received: 5335
28 Jan 2024 15:00 #291809
Replied by PCW on topic Plasmac hal output link
You probably want just:
The following user(s) said Thank You: greekart
- greekart
28 Jan 2024 21:03 - 28 Jan 2024 21:08 #291831
by greekart
Replied by greekart on topic Plasmac hal output link
Thanks to your answer i get the point to overcome this and make it work. Much to understand yet but i am getting to it.
Thank you!
Thank you!
Last edit: 28 Jan 2024 21:08 by greekart.
Time to create page: 0.358 seconds
