THC and run from line
  • mariusl
  • mariusl's Avatar Topic Author
  • Platinum Member
  • Platinum Member
04 Feb 2024 14:03 #292387 by mariusl
THC and run from line was created by mariusl
Hi
We have a system that the customer uses run from line regularly and he reports that the THC does not work at all. The Gcode includes the THC enable and it is enabled on the Gui but there is no reaction to the voltage changes.
The mode is set to 1.
This is the beginning of the file but they started it somewhere down the line.
N00010;     file name: 2 inch Cutter with RT 2 (6mm ms)Bennox Plasma cutting Rev 6 full sheet.ngc
N00020; date and time: Fri Feb 02 2024    18:16:21
N00030; postprocessor: LinuxCNC PlasmaC.scpost rev: 0.4
N00040;
N00050;begin pre-amble
N00060 G21 (units: metric)
N00070 G40 (cutter compensation: off)
N00080 G90 (distance mode: absolute)
N00090 M52 P1 (adaptive feed: on)
N00100 M65 P2 (enable THC)
N00110 M65 P3 (enable torch)
N00120 M68 E3 Q0 (velocity 100%)
N00130 G64 P0.254 Q0.025 (tracking tolerances: 0.254mm)
N00140#<holes>      = 2
N00150#<h_velocity> = 40
N00160#<h_diameter> = 32
N00170#<oclength>   = 2
N00180;end pre-amble
N00190 M67 E3 Q100
N00200;
N00210;begin material setup
N00220 T0 M6 (select plasma tool)
N00230 G43 H0 (apply tool offsets)
N00240 M190 P7 (6mm mild steel [shielded consumables 55amps] material)
N00250 M66 P3 L3 Q2 (wait for valid change)
N00260 F#<_hal[plasmac.cut-feed-rate]>
N00270;end material setup
N00280 G0 X23.707 Y94.647
N00290 M3 $0 S1 (plasma start)
N00300 M67 E3 Q100
Regards
Marius
www.bluearccnc.com
04 Feb 2024 14:16 #292391 by tommylight
Replied by tommylight on topic THC and run from line
Can you get a screenshot of the settings page and main page when using run from line?
  • mariusl
  • Platinum Member
  • Platinum Member
04 Feb 2024 14:49 #292403 by mariusl
Replied by mariusl on topic THC and run from line
I am not near the machine at the moment but I just tested on my machine and there is no problem with the THC enable. I will first have to see if that machine needs to be updated.
The main screen has:
Torch Enable = On
Velocity Anti Dive = On
Auto Volts = On
THC Enable = On
THC Enable Led = Off
Up/Down and Active Leds = Off
Regards
Marius
www.bluearccnc.com
05 Feb 2024 03:35 #292481 by phillc54
Replied by phillc54 on topic THC and run from line
Could you get a copy of the actual run from line code by setting it up and loading it then right click on the g-code text and select all then copy and paste into a text editor.
Does the THC show as enabled on the GUI while cutting?
  • mariusl
  • Platinum Member
  • Platinum Member
05 Feb 2024 06:21 - 05 Feb 2024 06:21 #292486 by mariusl
Phill the THC Enabled Led never comes on. Let me get the installation up to the latest code today and check again.
Regards
Marius
www.bluearccnc.com
Last edit: 05 Feb 2024 06:21 by mariusl.
05 Feb 2024 06:43 #292488 by phillc54
Is that only when doing run from line or also on a full job.
Is it possible that the machines cutting velocity does not reach the cut speed set in the parameters.
  • mariusl
  • Platinum Member
  • Platinum Member
05 Feb 2024 06:59 - 05 Feb 2024 07:00 #292489 by mariusl
I never thought about that. The machine is a bit slow but this was cutting at about 900mm/m. I think I saw 3000mm velocity during jogging on the machine.
The THC never comes on by the looks of it
Regards
Marius
www.bluearccnc.com
Last edit: 05 Feb 2024 07:00 by mariusl.
  • mariusl
  • Platinum Member
  • Platinum Member
05 Feb 2024 08:19 - 05 Feb 2024 08:20 #292493 by mariusl
This installation is on master-rtpreempt although it could be far behind as I cannot get to connect to the repository.
Regards
Marius
www.bluearccnc.com
Last edit: 05 Feb 2024 08:20 by mariusl.
  • mariusl
  • Platinum Member
  • Platinum Member
05 Feb 2024 08:54 #292494 by mariusl
I have changed this installation to the latest 2.9.2 now so we can go test it later today.
I will let you know if it changed anything
Regards
Marius
www.bluearccnc.com
05 Feb 2024 09:01 #292495 by phillc54
If you still have issues can you post the config backup created from the settings tab.
The following user(s) said Thank You: mariusl
Time to create page: 0.624 seconds
