QtPlasmac external pot for jog speed.
  • greekart
  • greekart's Avatar Topic Author
  • Junior Member
  • Junior Member
09 Feb 2024 14:27 - 09 Feb 2024 14:29 #292938 by greekart
QtPlasmac external pot for jog speed. was created by greekart
Hi everybody,i have trouble find why not the external pot work for jog-speed. Need to look something into files of qtplasmac or need to use a certain pin from plasmac like plasmac.current-velocity?
Feed-override and Rapid-override works as expected.
Thanks a lot Panos
Last edit: 09 Feb 2024 14:29 by greekart. Reason: not like how bold look like
09 Feb 2024 23:18 #292963 by cmorley
Replied by cmorley on topic QtPlasmac external pot for jog speed.
What have you tried?
  • greekart
  • Junior Member
  • Junior Member
10 Feb 2024 09:54 - 12 Feb 2024 08:05 #292983 by greekart
Replied by greekart on topic QtPlasmac external pot for jog speed.
loadrt hyst names=hyst.jogpot
loadrt scale names=scale.jog
net jogpot-raw hm2_7i96s.0.7i73.0.0.analogin0
#### Jog-Override
addf scale.jog servo-thread
addf hyst.jogpot servo-thread
setp hyst.jogpot.gain 0.05
setp hyst.jogpot.deadband 0.7
setp hyst.jogpot.step 0.01
setp hm2_7i96s.0.7i73.0.0.analogin1-scalemax 32
#setp plasmac.override-jog true  **i try with that
net  jogpot-raw         hyst.jogpot.in
setp scale.jog.in       5000
setp scale.jog.offset   50
net jog-speed-gain     hyst.jogpot.out    scale.jog.gain
#net jog-speed-gain  halui.axis.jog-speed hyst.jogpot.out  scale.jog.gain ** something else i try
This is the code i try to use but i had try few pins i see in hal-show with no success and i wonder if is a chain that i need to enable to make it work, if you can point me to the right direction i will appreciate. Thanks a lot
Last edit: 12 Feb 2024 08:05 by greekart. Reason: I forget something
11 Feb 2024 04:02 #293054 by cmorley
I see no HAL jog speed setting pins for Qtplasmac.
HALUI jog speed is separate from Qtplasmac.
If you use HALUI jog speed then you must use HALUI jogging too.
Maybe the Qtplasmac developers have better ideas for you.
  • greekart
  • Junior Member
  • Junior Member
11 Feb 2024 18:59 #293106 by greekart
Ok thank you!!
12 Feb 2024 01:15 #293121 by phillc54
Replied by phillc54 on topic QtPlasmac external pot for jog speed.
I am not sure how you would want this to work, wouldn't having an external pot require inhibiting any changes from the GUI as they would not be in sync with the pot.
  • greekart
  • Junior Member
  • Junior Member
12 Feb 2024 08:11 #293139 by greekart
I wanted to add it as it have it in gui and i prefer that way from the moment i have external axis jog.
So you mean that i should forget it?
I can just add the fast/slow button overall..
13 Feb 2024 01:43 #293182 by phillc54
No, we could probably cobble something up but we would need to disable any jog rate adjustments in the GUI as they cannot synchronise an external pot. Fast/Slow could probably stay and the pot would be the only way to adjust the jog rate.
If you were happy with buttons only rather than a pot then it would be easy to add external increment and decrement inputs as well as a scale input.
13 Feb 2024 05:28 #293197 by phillc54
Hopefully this is close to what you want.
It adds a pin qtplasmac.ext_jog_override which takes a float value from 0 to 100 and sets the jog rate to that percentage of the maximum allowed value of the jog slider. It also disable all internal GUI setting of the jog slider.
Copy the attached file into the config directory as qtplasmac_custom.py then start LinuxCNC.
File Name: qtplasmac_...02-13.py
File Size:2 KB
The following user(s) said Thank You: greekart, gekonko
  • greekart
  • Junior Member
  • Junior Member
13 Feb 2024 09:49 #293210 by greekart
File Size:2 KB
Closer than that couldn't be, thanks a lot!!
Is working, i don't have physical button for fast/slow yet but from gui/halshow it looks that work too as expected.
Thanks again!!
Time to create page: 0.385 seconds
