G64 Pn Qn Value Problems when running from Line in Qtplasmac
16 Feb 2024 10:02 #293490 by Deveraux
So im running qtplasmac v2.9-236.302. Yesterday i discovered a problem when running from line.
In general the Fusion PP puts in The G64 Pn and Qn values which i adjusted because the machine will start to round corners otherwise.
Now if i want to run a Program from line it loads the rfl.ngc temporary cut file. But when the file loads my G64 values are gone and the machine will start to round corners again. Any Suggestion on where to find the G64 Settings/Initialisation values for rfl.ngc?
Hope you can help thanks in advance.
16 Feb 2024 10:10 #293493 by Aciera
Have you tried setting your G64 Pn Qn in the [RS274NGC] section of your ini file?
RS274NGC_STARTUP_CODE =
16 Feb 2024 12:58 #293504 by Deveraux
Thanks for the quick answer this is probably exactly what i was looking for. I will try it as soon as i startup the cutter today.
Many thanks.
16 Feb 2024 16:29 #293519 by Deveraux
I just tried modifying The RS274 startup code unfortunately it did not change anything in the rfl.ngc its still just the G64 command without any Pn or Qn values.
16 Feb 2024 16:43 #293520 by tommylight
Moved to PlasmaC section.
What does rfl.ngc do?
16 Feb 2024 22:46 #293547 by phillc54
I see this issue as well, it is a bug. I will look at it later today.
rfl.ngc is the G-code created for a run from line job.
16 Feb 2024 23:42 #293555 by tommylight
So a temporary file, nice.
Where does it get created? Just in case i ever need it.
16 Feb 2024 23:45 #293557 by phillc54
/tmp/qtplasmac/rfl.ngc along with a few others.
I have found the problem and will merge the fix shortly.
17 Feb 2024 00:06 #293561 by phillc54
The fix has been pushed to 2.9 and master so should be available when the buildbots build the packages.
17 Feb 2024 09:41 #293600 by Deveraux
Wow that was fast as always thanks. That really helps a lot at first i thought i overlooked something in the configs. Though it normally isn't necassary to run from a specific line it always is nice to have for cut recovery.
Many thanks
Time to create page: 0.947 seconds
