Translation files for QtPlasmaC
17 Feb 2024 15:33 #293656 by Franklin
Translation files for QtPlasmaC was created by Franklin
Hi everyone who tried to create a translation file? I did everything according to the instructions and it doesn't work. I have this error "bash: langfile: command not found"
What am I doing wrong?
18 Feb 2024 03:55 - 18 Feb 2024 03:56 #293677 by phillc54
Replied by phillc54 on topic Translation files for QtPlasmaC
Is there a script named langfile in your current directory and is it executable?
Are you running a package installation or a run in place installation?
Last edit: 18 Feb 2024 03:56 by phillc54.
18 Feb 2024 06:25 #293680 by Franklin
Replied by Franklin on topic Translation files for QtPlasmaC
Yes the langfile is present in the directory but I can't execute it. I use run in place installation and run command "langfile ua" from directory cd ~/linuxcnc-dev/share/qtvcp/screens/qtplasmac/languages
18 Feb 2024 20:34 #293737 by phillc54
Try adding ./ in front of langfile, like:
./langfile xx
19 Feb 2024 02:33 #293749 by Franklin
It worked, thanks.
Is it possible to do this in the package installation (Buildbot)?
19 Feb 2024 02:38 #293750 by phillc54
To be honest I have not tried. The directory would be in a system directory so you would need elevated privileges like sudo.
19 Feb 2024 16:07 - 19 Feb 2024 16:08 #293795 by Franklin
I tried to translate the interface but qtplasmac doesn't see my langfile.  This is probably a problem with my system locale?
# locale
LANG=uk_UA.UTF-8
Last edit: 19 Feb 2024 16:08 by Franklin.
19 Feb 2024 17:06 #293805 by phillc54
Can you post the language file, I will make a new virtual machine for testing. You may need to add .txt to end so the forum accepts it.
19 Feb 2024 17:30 - 19 Feb 2024 17:34 #293808 by Franklin
I tried renaming it to qtplasmac_uk and nothing changed.
language file:
File Name: qtplasmac_ua.txt
File Size:156 KB
Last edit: 19 Feb 2024 17:34 by Franklin.
19 Feb 2024 19:14 - 19 Feb 2024 19:18 #293812 by phillc54
The file end needs to be the first two letters from locale, so in your case it would be qtplasmac_uk.ts
Warning: Spoiler!
Edit: did you create the .qm file
Last edit: 19 Feb 2024 19:18 by phillc54.
Time to create page: 0.129 seconds
