Greetings,
My trusty computer died, I rebuilt on a Bookworm-based machine, and installed Linuxcnc-uspace master from buildbot2.highlab.com.
Now in any file, if I click somewhere on the drawing to do Run From Line, after hitting ok in the dialog that pops up (from here to end option) then I get this notice.
Qtvcp encountered an error.
The following information may be useful in troubleshooting:
LinuxCNC Version : 2.10.0-pre0-3202-g19ad8990e8
Traceback (most recent call last):File "/usr/share/qtvcp/screens/qtplasmac/qtplasmac_handler.py", line 1948, in run_clickeddata = RFL.run_from_line_get(self.lastLoadedProgram, self.startLine, lastLine)^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^File "/usr/lib/python3/dist-packages/plasmac/run_from_line.py", line 79, in run_from_line_getmaterial[1] = line.strip()~~~~~~~~^^^IndexError: list assignment index out of range
QtPlasmaC version 2.10-008.044
Let me know if you need any of my config backups or more detail in order to reproduce. I've tried on various ngc files, all with the same result.
