Plasmac Breakaway roadblock (mental one anyway)
- Thank you received: 4150
10 Aug 2024 02:17 #307396
Plasmac Breakaway roadblock (mental one anyway) was created by rodw
Is this right?
I'm confused here. Ihm2_7i76e.0.7i76.0.0.input-20 lights up in halshow
but plasmac:breakaway does not change state so neither does the pin
Any ideas?
# --- PLASMAC:BREAKAWAY ---
net plasmac:breakaway <= hm2_7i76e.0.7i76.0.0.input-20
net plasmac:breakaway => db_breakaway.inI'm confused here. Ihm2_7i76e.0.7i76.0.0.input-20 lights up in halshow
Any ideas?
- phillc54
- Thank you received: 2100
10 Aug 2024 04:20 #307399
by phillc54
Replied by phillc54 on topic Plasmac Breakaway roadblock (mental one anyway)
If you show the signal plasmac:breakaway in HalShow does it confirm that the connected pins are correct.
10 Aug 2024 08:31 #307407
Replied by rodw on topic Plasmac Breakaway roadblock (mental one anyway)
No, that is the confusing bit. The signal does not change state.If you show the signal plasmac:breakaway in HalShow does it confirm that the connected pins are correct.
09 Sep 2024 11:51 #309736
I have revisited this and plasmac.breakaway now goes true but ot does not pause.
Any more Ideas?
Config is in git here github.com/rodw-au/showstopper
Any more Ideas?
Time to create page: 0.198 seconds
