Plasmac2QTplasma gives error not a Plasmac configuration /solved
  • CNCFred
  • CNCFred's Avatar Topic Author
  • Elite Member
  • Elite Member
18 Aug 2024 15:51 - 18 Aug 2024 19:23 #308080 by CNCFred
Dear all,
after trying to update my hardware and the necessary disassemble the project got stuck for years
sorry the edit deleted the rest of my original message.....couldn't retrieve it..
Last edit: 18 Aug 2024 19:23 by CNCFred.
18 Aug 2024 17:32 #308093 by snowgoer540
As the length of time between the creation of QtPlasmaC, and no longer supporting the original PlasmaC (that sat on top of Axis) grew, the support for the conversion from one to the likely/unfortunately fell off the radar.
Having a backup of your config folder would help to diagnose the issue, but if I'm being honest so much has changed that it might not be worth the effort on our part.  I talk to Phill, but the best move might be for us to discontinue the conversion script in favor of directing everyone toward creating a new config with pncconf.  At the time Phill made the script, pncconf did not support QtPlasmaC natively.  It now does.  That means it's no longer necessary to make a working axis config, and then run the PlasmaC configurator, conversion script etc.  You can do everything all at once now in pncconf.
That said, I know it's not as convenient for the end user.  Post a backup of your configuration if you'd like, but no promises on if/when the conversion script might get updated.  Like I say, I would recommend just creating the config from scratch in pncconf using QtPlasmaC as the GUI you'd like to use.
Sorry for the inconvenience :-/
  • CNCFred
  • Elite Member
  • Elite Member
18 Aug 2024 19:15 #308104 by CNCFred
Thank you for you kind reply and offer, no worries , the error is on my side not being up to date, you are all busy enough.
I had a 7i76e.pncconf file which I was able to open with pncconf and my settings were there at least seems ok for the default machine.
I was using a xbox controller, a two button crane control with emergency stop and the laser was with a M7 command- button set to the mist hal output.
I will read the documentation and hopefully get all working with the qtplasmac machine setup again.
I assume the additional config is the same, custom hal etc.
thank you
Roman
Time to create page: 0.203 seconds
