- Thank you received: 22
Inssues Arc Start
2 years 2 months ago #308836
by paulsao
Inssues Arc Start was created by paulsao
Greetings to all.
Very recently I have been experiencing failures in starting the arc, it has never happened to me when I go to cut something the arc fails even up to 3 times, could someone help me with this.
2 years 2 months ago #308850
Replied by tommylight on topic Inssues Arc Start
What did you change?
Did you change the power socket for any of the equipment?
Did you have any work done in the power distribution panel?
Check for broken ground wires and for nicked wiring on moving parts of the machine.
The following user(s) said Thank You: paulsao
2 years 2 months ago #308852
Replied by rodw on topic Inssues Arc Start
What plasma cutter?
How are you getting an ArcOK signal? From the plasma cutter?
It could be oxidisation of the relay contacts.
2 years 2 months ago #308895
by paulsao
Replied by paulsao on topic Inssues Arc Start
Good morning, I'll tell you some updates:
1) The plasma is the lotos 5500 model.
ipt60 torch.
2) I hear that the relay and the solenoid valve activate but the arc does not come out, does that mean that the relay is good?
3) I can also see in Qtpaslamc that the arc voltage is more or less 229v but the arc does not come out of the torch.
My suspicion is that the torch could be failing...is there anything inside it that can be cleaned or damaged?
ipt60 torch.
2 years 2 months ago #308897
-check air pressure while the air is on
-remove nozzle and electrode and look inside the torch, is there charring and black spots? If yes, clean as much as you can with a sharp screwdriver, blow the dust with compressed air, use WD40 and spray inside the torch. Put new electrode and nozzle, test.
If the ceramic parts inside are eroded and blacked to much = new torch.
Are the consumables original?
If the new electrode gets blacked after several failed tries = new torch.
As a general rule, never fire the torch with no air, these china made plasma cutters do not have a pressure sensor so they will fire with no air and destroy the torch.
2 years 2 months ago #308923
This is my guess
linuxcnc.org/docs/stable/html/plasma/qtp...asma:qt-contact-load
It will take time for the oxidisation to burn off maybe 10 cycles or more.
