Where is qtplasmac_comp.hal loaded
  • rodw
  • rodw's Avatar Topic Author
  • Platinum Member
  • Platinum Member
07 Sep 2024 21:59 #309616 by rodw
Just finalising an implementation of qtplasmac on a retrofit and we don't seem to have the breakaway and float switch connected
I know these should be connected to plasmac.float-switch and plasmac.breakaway
These seem to be connected in qtplasmac_comp.hal but I can't see this hal file is being loaded anywhere in our config so maybe we broke something. If that is the case, there are a lot of other signals unconnected.
Can someody set me straight here?
  • rodw
  • Platinum Member
  • Platinum Member
07 Sep 2024 22:26 #309618 by rodw
Replied by rodw on topic Where is qtplasmac_comp.hal loaded
Got it. I ran up a new config with pncconf and indeed the ini file was missing
HALFILE = qtplasmac_comp.hal
in the ini file. It must have been deleted along the way.
  • rodw
  • Platinum Member
  • Platinum Member
09 Sep 2024 11:54 #309737 by rodw
As it turned out I was loading this but I was also loading most of my config first. Moving it up to just after my main hal file solved any issues. It seems twopass is not really doing its job...
