Qtplasmac SIM Estop Label
- Plasmanfm
- Thank you received: 22
12 Sep 2024 08:57 - 12 Sep 2024 10:22 #309978
by Plasmanfm
Qtplasmac SIM Estop Label was created by Plasmanfm
Since I create the G-Code at home ....
Characters with Freecad ...Sheetcam
I check the result with qtplasmac_I_metric
Then drive with me to my hall and cut as far as possible, very good but what notice is this EStop label!
No matter what Estop setting I take the label I always have whether 0, 1 or 2!
Can you change that?
King regard
Juergen
King regard
Juergen
Last edit: 12 Sep 2024 10:22 by Plasmanfm.
- phillc54
- Thank you received: 2100
13 Sep 2024 00:06 #310037
by phillc54
Replied by phillc54 on topic Qtplasmac SIM Estop Label
If you want to change the function then you would need to make the appropriate HAL connections as well.
- Plasmanfm
13 Sep 2024 09:04 #310055
by Plasmanfm
Replied by Plasmanfm on topic Qtplasmac SIM Estop Label
Ok..
what do change in the hal and where is the hal in the sim
King regarde
Juergen
King regarde
Juergen
Time to create page: 0.461 seconds
