Update failure
- chuben
16 Oct 2024 12:29 - 16 Oct 2024 19:26 #312249
by chuben
Update failure was created by chuben
Hello, I am trying to update Qtplasma and when I update repositories I get this error: NO_PUBKEY EF1B07FEE0EE663EEl.
Repositori
Binary deb:
Url: buildbot.linuxcnc.org
Distribution: buster
Section: master-rtpreemt.
Sources deb-src:
Url: buildbot.linuxcnc.org/
Repositori
Binary deb:
Sources deb-src:
Last edit: 16 Oct 2024 19:26 by chuben.
- phillc54
- Thank you received: 2100
16 Oct 2024 22:30 #312308
by phillc54
Replied by phillc54 on topic Update failure
LinuxCNC no longer supports Buster, the last Buster master branch build was July 6th.
buildbot.linuxcnc.org/dists/buster/maste...inary-amd64/?C=M;O=D
To get the latest master branch you would be better off "upgrading" to Bookworm, packages are available on the other buildbot:
buildbot2.highlab.com/
Having said that, it seems the other buildbot has not built master branch since Oct 5th...
- chuben
17 Oct 2024 15:29 - 17 Oct 2024 16:00 #312402
by chuben
Replied by chuben on topic Update failure
Gracias por tu respuesta, pero llámame estúpido, pero no puedo descargar la última versión. La versión que se ha descargado es la 1.235.265.
He actualizado Debian 12 a bookworm y el kernel es 6.1.0.26-rt-amd64
Last edit: 17 Oct 2024 16:00 by chuben.
- phillc54
17 Oct 2024 22:16 - 17 Oct 2024 22:28 #312436
by phillc54
You need to set the repository in Synaptic toplus you need to copy the key as shown for the new style. This is all shown here:
deb http://buildbot2.highlab.com/debian/ bookworm master-uspacebuildbot2.highlab.com/
Last edit: 17 Oct 2024 22:28 by phillc54. Reason: Fix bold highlight
- Thank you received: 7481
17 Oct 2024 22:25 #312440
Replied by tommylight on topic Update failure
deb buildbot2.highlab.com/debian/ bookworm master-uspace
- phillc54
17 Oct 2024 22:29 #312442
by phillc54
Thanks Tom, it took me four goes to get that right...
- chuben
18 Oct 2024 19:50 - 18 Oct 2024 19:56 #312548
by chuben
I do sudo nano /etc/apt/trusted.gpg.d. A terminal opens and I paste buildbot-archive-key.gpg but when I try to save it it tells me which file I want to write it in and I don't know which one I should do it in.
Thank you but I am not able to put the keys in. I don't know which file to save them in.phillc54 publicación=312436 id de usuario=6129Debe configurar el repositorio en Synaptic para
deb http://buildbot2.highlab.com/debian/ bookworm master-uspace plus you need to copy the key as shown for the new style. This is all shown here: http://buildbot2.highlab.com/
Last edit: 18 Oct 2024 19:56 by chuben.
- phillc54
18 Oct 2024 23:16 - 18 Oct 2024 23:17 #312559
by phillc54
If you download the file to the ~/Downloads directory then do the following:
sudo cp ~/Downloads/buildbot-archive-key.gpg /etc/apt/trusted.gpg.d/
Last edit: 18 Oct 2024 23:17 by phillc54.
- chuben
19 Oct 2024 07:41 #312579
by chuben
I do what you tell me but when I go to update the repository I get this error: The repository "buildbot2.highlab.com debian Release" does not have a Release file. It cannot be updated from a repository like this safely and is therefore disabled by default. See the apt-secure man page (8) for details on creating repositories and configuring users. The “buildbot.linuxcnc.org bookworm Release” repository does not have a Release file.If you download the file to the ~/Downloads directory then do the following:
- phillc54
19 Oct 2024 10:45 #312591
by phillc54
I think that I get this message as well but I also think that it still does work.
Try apt search linuxcnc after sudo apt update and see if the last built package from here is shown.
buildbot2.highlab.com/debian/dists/bookw...inary-amd64/?C=M;O=D
it is currently 2.10.0~pre0.3694.g620332fdf4
Time to create page: 0.252 seconds
