Controlling a compressor with Linuxcnc.
08 Nov 2024 05:20 #314062 by Creative25
Replied by Creative25 on topic Controlling a compressor with Linuxcnc.
I struggle to find an electric unloader valve
on all of them it states for oil less compressors. Does that mean the seals will deteriorate from compressor oil? Or is it nothing to worry about?
08 Nov 2024 23:33 #314102 by Grotius
Replied by Grotius on topic Controlling a compressor with Linuxcnc.
Years ago i had the same problem as you. Was cutting a Thermal Dynamics 200 Amps + compressor + cnc.
I managed to get a diesel power pack on a trailer.
So if you are like a professor you could manage to create a big iron flywheel in your workshop.
Driven direct drive by a electromotor.
Say the flywheel mass is about 2000kg, rotating at 500 rpm. This will solve power dips for the whole street.
It's a silent & cheap solution.
09 Nov 2024 07:35 #314112 by Creative25
Unfortunately a flywheel will not work either.
If the compressor starts during probing it will only run for a short time and will cut out because of under voltage.
I do not cut a lot yet. So I can’t afford a diesel generator.
13 Nov 2024 01:02 #314355 by phillc54
Replied by phillc54 on topic Controlling a compressor with Linuxcnc.
This post  has been edited to suit a pressure sensor on a analog input.
The following user(s) said Thank You: Creative25
Time to create page: 0.445 seconds
