Defaults in QTplasmac
- CopperHead
05 Nov 2024 16:47 #313827
by CopperHead
Defaults in QTplasmac was created by CopperHead
I'm curious and maybe this has been answered before, But in QTplasmac I import my part that was created in Sheetcam it has the settings in it for material and cut information but QTplasmac has a drop down for the material as well. should it update to the material specified in the file or do I need to manually adjust this? Also what is the default it reads the dropdown or the information in the file itself?
- phillc54
- Thank you received: 2100
05 Nov 2024 22:14 #313857
by phillc54
Replied by phillc54 on topic Defaults in QTplasmac
You should have SheetCam set up to either use the materials that are in QtPlasmaC or to create the materials as required.
If you have something like below in the G-code file:then SheetCam is creating the materials.
linuxcnc.org/docs/devel/html/plasma/qtpl...lasma:magic-comments
The default material in QtPlasmaC is set on the SETTINGS tab.
(o=0, nu=2, na=5mm Mild Steel 40A, ph=3.1, pd=0.1, ch=0.75, fr=3000)linuxcnc.org/docs/devel/html/plasma/qtpl...lasma:magic-comments
- Creative25
- Thank you received: 11
14 Nov 2024 06:53 #314425
by Creative25
I use free sheetcam for very small files.
I get the above mentioned code in any file it creates.
Normally on line 23
It prevents Qtplasmac from using the material I chose in Qtplasmac.
I always delete that file.
Are there some settings to prevent Sheetcam from creating this line.
I want to handle material settings from Qtplasmac exclusively.
Replied by Creative25 on topic Defaults in QTplasmac
After a search I just found this post.You should have SheetCam set up to either use the materials that are in QtPlasmaC or to create the materials as required.
If you have something like below in the G-code file:(o=0, nu=2, na=5mm Mild Steel 40A, ph=3.1, pd=0.1, ch=0.75, fr=3000) then SheetCam is creating the materials. http://linuxcnc.org/docs/devel/html/plasma/qtplasmac.html#plasma:magic-comments The default material in QtPlasmaC is set on the SETTINGS tab.
Normally on line 23
- phillc54
18 Nov 2024 04:28 #314714
by phillc54
I use the attached post processor to do the same (you will need to remove the .txt from the end)
I have a material number 0 in SheetCam and when the post processor sees material 0 it removes any material change and when the G-code is first run it pauses and prompts that the correct material is selected in QtPlasmaC.
- CopperHead
19 Nov 2024 14:55 #314850
by CopperHead
Replied by CopperHead on topic Defaults in QTplasmac
Just getting back to this today. yesterday I cut some 3/16 yesterday and noticed as it started the file the default material changed to temporary material. I'm going to check the above items in my gcode to see what's being output.
- CopperHead
19 Nov 2024 14:58 #314851
by CopperHead
Ok this is the start of my gcode as output from sheetcam.
; date and time: Mon Nov 18 2024 13:16:07
; postprocessor: LinuxCNC PlasmaC.scpost rev: 0.4
;begin pre-amble
G20 (units: inches)
G40 (cutter compensation: off)
G90 (distance mode: absolute)
M52 P1 (adaptive feed: on)
M65 P2 (enable THC)
M65 P3 (enable torch)
M68 E3 Q0 (velocity 100%)
G64 P0.01 Q0.001 (tracking tolerances: 0.01")
#<holes> = 2
#<h_velocity> = 60
#<h_diameter> = 1
#<oclength> = 0
;end pre-amble
;begin material setup
T0 M6 (select plasma tool)
G43 H0 (apply tool offsets)
(o=0,kw=0.068, ph=0.15, pd=0.2, ch=0.06, fr=120, th=1, cv=99, pe=0, jh=0, jd=0)
F#<_hal[plasmac.cut-feed-rate]>
;end material setup
G0 X0.18162 Y4.32319
M3 $0 S1 (plasma start)
M67 E3 Q100
;begin pre-amble
G20 (units: inches)
M65 P2 (enable THC)
#<holes> = 2
#<h_velocity> = 60
#<h_diameter> = 1
#<oclength> = 0
;end pre-amble
;end material setup
M67 E3 Q100
- snowgoer540
- Thank you received: 907
19 Nov 2024 17:35 #314862
by snowgoer540
Replied by snowgoer540 on topic Defaults in QTplasmac
Seems like you’re still using the default post processor instead of the one Phill posted…
- CopperHead
19 Nov 2024 18:11 #314864
by CopperHead
Yes that one was the default. I just switched to the one Phil provided. Was able to run the materials in QTPlasmac but I seem to have an issue in Height control or maybe it was the consumable guess ill check that real quick...
Ok those look good but I'm getting intermittent raised cuts probably a settings issue in my HC but I've seen some PP create issues there as well. Im using the MESA THCad2 so its more than likely I haven't dialed that in correctly yet.
- CopperHead
19 Nov 2024 18:23 #314866
by CopperHead
Ok never mind i did have a very small blow out I didn't see in the tip. so that would account for the raised HC look
Time to create page: 0.246 seconds
