Path display glitching - QTPlasmaC - v1.235.265 QtVCP LinuxCNC v2.9.0
- RNJFAB
- Thank you received: 59
20 Jan 2025 00:59 #319426
by RNJFAB
Replied by RNJFAB on topic Path display glitching - QTPlasmaC - v1.235.265 QtVCP LinuxCNC v2.9.0
Thank you Tommy,
Knew it would be simple, brain fog last night stopped me from thinking.
All up and running !!!
I'm about to move it all then begin on getting the new plasma settings dialed in later this week.
linuxcnc
LINUXCNC - 2.9.3-125-g62642dde63
Machine configuration directory is '/home/cnc/linuxcnc/configs/T17'
Machine configuration file is 'T17.ini'
Starting LinuxCNC...
Note: Using POSIX realtime
Found file(REL): ./T17.hal
identityKinematicsSetup: coordinates:XYYZ
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Y
Joint 3 ==> Axis Z
identityKinematicsSetup: Recommend: kinstype=both
hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2
hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:16:03:5b
hm2_eth: discovered 7I96
hm2/hm2_7i96.0: Low Level init 0.15
hm2/hm2_7i96.0: Smart Serial Firmware Version 43
hm2/hm2_7i96.0: 51 I/O Pins used:
hm2/hm2_7i96.0: IO Pin 000 (TB3-01): IOPort
hm2/hm2_7i96.0: IO Pin 001 (TB3-02): IOPort
hm2/hm2_7i96.0: IO Pin 002 (TB3-03): IOPort
hm2/hm2_7i96.0: IO Pin 003 (TB3-04): IOPort
hm2/hm2_7i96.0: IO Pin 004 (TB3-05): IOPort
hm2/hm2_7i96.0: IO Pin 005 (TB3-06): IOPort
hm2/hm2_7i96.0: IO Pin 006 (TB3-07): IOPort
hm2/hm2_7i96.0: IO Pin 007 (TB3-08): IOPort
hm2/hm2_7i96.0: IO Pin 008 (TB3-09): IOPort
hm2/hm2_7i96.0: IO Pin 009 (TB3-10): IOPort
hm2/hm2_7i96.0: IO Pin 010 (TB3-11): IOPort
hm2/hm2_7i96.0: IO Pin 011 (TB3-13/TB3-14): SSR #0, pin Out-00 (Output)
hm2/hm2_7i96.0: IO Pin 012 (TB3-15/TB3-16): SSR #0, pin Out-01 (Output)
hm2/hm2_7i96.0: IO Pin 013 (TB3-17/TB3-18): SSR #0, pin Out-02 (Output)
hm2/hm2_7i96.0: IO Pin 014 (TB3-19/TB3-20): SSR #0, pin Out-03 (Output)
hm2/hm2_7i96.0: IO Pin 015 (TB3-21/TB3-22): SSR #0, pin Out-04 (Output)
hm2/hm2_7i96.0: IO Pin 016 (TB3-23/TB3-24): SSR #0, pin Out-05 (Output)
hm2/hm2_7i96.0: IO Pin 017 (TB1-02/TB1-03): StepGen #0, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 018 (TB1-04/TB1-05): StepGen #0, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 019 (TB1-08/TB1-09): StepGen #1, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 020 (TB1-10/TB1-11): StepGen #1, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 021 (TB1-14/TB1-15): StepGen #2, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 022 (TB1-16/TB1-17): StepGen #2, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 023 (TB1-20/TB1-21): StepGen #3, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 024 (TB1-22-TB1-23): StepGen #3, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 025 (TB2-02/TB2-03): StepGen #4, pin Step (Output)
hm2/hm2_7i96.0: IO Pin 026 (TB2-04/TB2-05): StepGen #4, pin Direction (Output)
hm2/hm2_7i96.0: IO Pin 027 (TB2-07/TB2-08): Encoder #0, pin A (Input)
hm2/hm2_7i96.0: IO Pin 028 (TB2-10/TB2-11): Encoder #0, pin B (Input)
hm2/hm2_7i96.0: IO Pin 029 (TB2-13/TB2-14): Encoder #0, pin Index (Input)
hm2/hm2_7i96.0: IO Pin 030 (TB2-16/TB2-17): IOPort
hm2/hm2_7i96.0: IO Pin 031 (TB2-18/TB2-19): IOPort
hm2/hm2_7i96.0: IO Pin 032 (internal): IOPort
hm2/hm2_7i96.0: IO Pin 033 (internal): SSR #0, pin AC Ref (internal) (Output)
hm2/hm2_7i96.0: IO Pin 034 (P1-01/DB25-01): IOPort
hm2/hm2_7i96.0: IO Pin 035 (P1-02/DB25-14): IOPort
hm2/hm2_7i96.0: IO Pin 036 (P1-03/DB25-02): IOPort
hm2/hm2_7i96.0: IO Pin 037 (P1-04/DB25-15): IOPort
hm2/hm2_7i96.0: IO Pin 038 (P1-05/DB25-03): IOPort
hm2/hm2_7i96.0: IO Pin 039 (P1-06/DB25-16): IOPort
hm2/hm2_7i96.0: IO Pin 040 (P1-07/DB25-04): IOPort
hm2/hm2_7i96.0: IO Pin 041 (P1-08/DB25-17): IOPort
hm2/hm2_7i96.0: IO Pin 042 (P1-09/DB25-05): IOPort
hm2/hm2_7i96.0: IO Pin 043 (P1-11/DB25-06): IOPort
hm2/hm2_7i96.0: IO Pin 044 (P1-13/DB25-07): IOPort
hm2/hm2_7i96.0: IO Pin 045 (P1-15/DB25-08): IOPort
hm2/hm2_7i96.0: IO Pin 046 (P1-17/DB25-09): IOPort
hm2/hm2_7i96.0: IO Pin 047 (P1-19/DB25-10): IOPort
hm2/hm2_7i96.0: IO Pin 048 (P1-21/DB25-11): IOPort
hm2/hm2_7i96.0: IO Pin 049 (P1-23/DB25-12): IOPort
hm2/hm2_7i96.0: IO Pin 050 (P1-25/DB25-13): IOPort
hm2/hm2_7i96.0: registered
Found file(lib): /usr/share/linuxcnc/hallib/qtplasmac_comp.hal
Found file(REL): ./custom.hal
[Errno 2] No such file or directory: '/home/cnc/linuxcnc/configs/T17/qtvcp/screens/qtplasmac'
No option 'Default material' in section: 'GUI_OPTIONS'
No option 'MainWindow-geometry' in section: 'SCREEN_OPTIONS'
Running HAL shutdown script
task: 3667 cycles, min=0.000008, max=0.011123, avg=0.009986, 0 latency excursions (> 10x expected cycle time of 0.010000s)
hm2_eth: in hm2_eth_reset
hm2_eth: HostMot2 ethernet driver unloaded
hm2: unloading
linuxcnc
Joint 0 ==> Axis X
Joint 1 ==> Axis Y
Joint 2 ==> Axis Y
Joint 3 ==> Axis Z
hm2: unloading
- Thank you received: 7488
20 Jan 2025 01:34 #319428
Replied by tommylight on topic Path display glitching - QTPlasmaC - v1.235.265 QtVCP LinuxCNC v2.9.0
The rest seems to be triggered by this.Found file(REL): ./custom.hal
- phillc54
- Thank you received: 2100
20 Jan 2025 02:45 #319433
by phillc54
Is there any more info on screen with "debug" in it?
Maybe post ~/linuxcnc_debug.txt and linuxcnc_print.txt after a unsuccessful run attempt.
Replied by phillc54 on topic Path display glitching - QTPlasmaC - v1.235.265 QtVCP LinuxCNC v2.9.0
I don't think that is the problem, I have just built a 2.9 VM using the same version and I see the same error message but it still loads correctly. I think that is an internal QtVCP message that probably should be muted normally.
The following user(s) said Thank You: tommylight, RNJFAB
Time to create page: 0.292 seconds
