Probe function not working after final adjustments
- MTTI
- Thank you received: 6
17 Feb 2025 21:09 - 17 Feb 2025 21:10 #321873
by MTTI
Probe function not working after final adjustments was created by MTTI
Hello,
During the initial setup and test adjustments I performed before the final assembly, the probe function was working correctly. Since I completed the final adjustments, particularly the connection and calibration of the encoders, the probe no longer works. Instead of moving down, it moves up until it reaches the home position.
My Z-axis has a large travel range, which is why I set a HOME_OFFSET of 100mm to position the torch closer to the table. Manual jogging is in the correct direction, and homing also works properly.
All the travel parameters were the same as those in the attached file when it was working, only INPUT_SCALE and OUTPUT_SCALE have changed.
Do you have any idea what could be causing this issue?
Last edit: 17 Feb 2025 21:10 by MTTI. Reason: Formating
- MTTI
19 Feb 2025 22:23 #322020
by MTTI
Replied by MTTI on topic Probe function not working after final adjustments
Quick update:
If I do a probe test when X and Y are at home the probe test works. But if I move away the Y axe from home, the torch lift up when I do a probe test...
I spend many time on this subject, if someone have an idea...
- MTTI
22 Feb 2025 08:52 - 22 Feb 2025 08:53 #322259
by MTTI
I found the problem but "too late", it was this line into the .hal exemple file from QtPlasmaC that i'm using:
net plasmac:axis-position joint.2.pos-fb => plasmac.axis-z-position
Into this configuration file the Z axis is supposed to be on joint.2 but it was in my case on joint.3 (joint.2 was Y2).
Last edit: 22 Feb 2025 08:53 by MTTI.
