Dreaming Question On Ohmic
01 Mar 2025 16:41 #322938 by CopperHead
Dreaming Question On Ohmic was created by CopperHead
I bring this crazy question and hope its already been done. A few days ago I saw a fibre laser run along and sense the layout of the material. Is it possible to get a similar function using ohmic, in allowing contact to be made and run along the sheet till the signal drops off? or better yet pick up a signal when its a smidge above the material so as to not run a grove in the metal and damage the tip?
01 Mar 2025 17:30 #322946 by RDA
Replied by RDA on topic Dreaming Question On Ohmic
I don't think dragging the torch on the plate is a good way in achieving the shape of the plate.
I think I saw someone making this with opencv. I would assume it’s way faster and you can see also “gaps” from example already cut parts.
01 Mar 2025 17:42 #322948 by CopperHead
Replied by CopperHead on topic Dreaming Question On Ohmic
Ya that's why I said or Better yet. I'm sure the fibre laser is using some form of ohmic as it doesn't touch the sheet I'm just not familiar enough with ohmic to know if it begins to receive a partial signal before it even makes contact. Ill look to see if i can find this opencv info
01 Mar 2025 17:50 - 01 Mar 2025 17:51 #322949 by rodw
Replied by rodw on topic Dreaming Question On Ohmic
I don't think so. The laser heads have capacitive height sensing built into them so they can read cut height without ever needing to probe and touch the surface.
Ohmic sensing uses  a physical probe and does not give that continuous height reading.
Last edit: 01 Mar 2025 17:51 by rodw.
01 Mar 2025 17:54 #322950 by rodw
With ohmic, touching the surface acts like a switch so its either on or off.
01 Mar 2025 18:06 #322952 by CopperHead
Ok. I wasnt sure if there might be a slight reading before touch. Couldn't a hall sensor be used to read height above material? I know when i was in the concrete industry we had laser sensors that would measure distance and turn off feed belts when a hopper was at a certain level of concrete.
02 Mar 2025 15:59 #323022 by RDA
One thing is to find the edges of the plate, another is using scrap plate that can have holes from already cut parts. If you just want to find edges and always have square plates the you can use capacitive, laser range sensors or almost anything that senses metal.
In my mind the time saved is quite minimal and only works for squares or rectangles. Well of course you could run a line on all edges but would it be worth it, not really sure.
The camera stuff would be way nicer, example stuff like this Trumpf cut and drop . Libellula Optia the video could show case it better but basically you take a picture of the sheet and then you can nest to it.
Time to create page: 0.442 seconds
