updating to QtPlasmac, copying setting from plasmaC?
  • JTknives
  • JTknives's Avatar Topic Author
  • Elite Member
  • Elite Member
07 Mar 2025 21:10 #323466 by JTknives
I'm starting over with a fresh install of the new QtPlasmaC on a new HD. I'm wondering if there is a way to just copy over my config data as its been so long that all these questions in the pncconf are greek now. Here is my old file
# Generated by PNCconf at Sun Jan 10 18:01:51 2021
# Using LinuxCNC version:  2.8
# overwritten when you run PNCconf again
[EMC]
MACHINE = IMPERIAL_PLASMAC
DEBUG = 0
VERSION = 1.1
[DISPLAY]
DISPLAY = gmoccapy
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 1.000000
MIN_SPINDLE_OVERRIDE = 0.500000
INTRO_TIME = 5
PROGRAM_PREFIX = /home/jtknives/linuxcnc/nc_files
INCREMENTS = .1in .05in .01in .005in .001in .0005in .0001in
DEFAULT_LINEAR_VELOCITY = 0.250000
MAX_LINEAR_VELOCITY = 1.000000
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_ANGULAR_VELOCITY = 12.000000
MAX_ANGULAR_VELOCITY = 180.000000
MIN_ANGULAR_VELOCITY = 1.666667
EDITOR = gedit
GEOMETRY = xyz
[FILTER]
png = image-to-gcode
gif = image-to-gcode
jpg = image-to-gcode
py = python
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 1000000
[HMOT]
# **** This is for info only ****
CARD0=hm2_7i76e.0
[HAL]
HALUI = halui
HALFILE = machine.hal
HALFILE = plasmac.hal
POSTGUI_HALFILE = postgui_call_list.hal
SHUTDOWN = shutdown.hal
[HALUI]
[KINS]
JOINTS = 3
KINEMATICS = trivkins coordinates=XYZ
[TRAJ]
COORDINATES =  XYZ
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
DEFAULT_LINEAR_VELOCITY = 0.83
MAX_LINEAR_VELOCITY = 8.3300
[EMCIO]
EMCIO = io
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[AXIS_X]
MAX_VELOCITY = 8.3333333
MAX_ACCELERATION = 150.0
MIN_LIMIT = -60.0
MAX_LIMIT = .001
[JOINT_0]
TYPE = LINEAR
HOME = 0.0c
FERROR = 0.5
MIN_FERROR = 0.05
MAX_VELOCITY = 8.33333333
STEPGEN_MAXVEL = 10.42
STEPGEN_MAXACCEL = 187.50
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
# these are in nanoseconds
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 1940.17
MIN_LIMIT = -60.0
MAX_LIMIT = .001
HOME_OFFSET = 0.0
[AXIS_Y]
MIN_LIMIT = -26.0
MAX_LIMIT = .001
[JOINT_1]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
MIN_LIMIT = -0.26.0
MAX_LIMIT = .001
HOME_OFFSET = 0.0
[AXIS_Z]
MAX_VELOCITY = 16.666
MAX_ACCELERATION = 300.0
MIN_LIMIT = -.001
MAX_LIMIT = 4.0
[JOINT_2]
TYPE = LINEAR
HOME = 0.0
FERROR = 0.5
MIN_FERROR = 0.05
P = 1000.0
I = 0.0
D = 0.0
FF0 = 0.0
FF1 = 1.0
FF2 = 0.0
BIAS = 0.0
DEADBAND = 0.0
MAX_OUTPUT = 0.0
DIRSETUP   = 10000
DIRHOLD    = 10000
STEPLEN    = 5000
STEPSPACE  = 5000
STEP_SCALE = 6400.0
MIN_LIMIT = -.001
MAX_LIMIT = 4.0
HOME_OFFSET = 0.0
[SPINDLE_9]
P = 0
I = 0
D = 0
FF0 = 1
FF1 = 0
FF2 = 0
BIAS = 0
DEADBAND = 0
MAX_OUTPUT = 2000
  • JTknives
  • Elite Member
  • Elite Member
07 Mar 2025 22:03 #323470 by JTknives
Here are all the files i think from my old installation. if i'm missing any please let me know and i will upload the missing ones. thankyou
File Name: Black_Hole...07-2.ini
File Size:4 KB
File Name: machine_20...3-07.hal
File Size:10 KB
File Name: plasmac_config.hal
File Size:3 KB
File Name: plasmac_co...ions.hal
File Size:2 KB
Time to create page: 0.108 seconds
