Hypertherm Powermax Voltage Divider, Preference for THAD-10
1 year 6 months ago #325512 by EW_CNC
Which voltage divider setting is prefferred for a Hypertherm Powermax plasma cutter when connected to a Mesa THAD-10?
The options are 20:1 _ 21.1:1 _ 30:1 _ 40:1 _ 50:1
Is one preferred over the other for better resolution or response time?
1 year 6 months ago #325526 by grijalvap
50:1 worked well you can use the THCAD10 without any modification,
Some good practices are:
-Place THCAD10 as close as possible to the Plasma power supply.
-Use a shield cable and connect the shield to GND on one side only.
-Use a ferrite bead on the control side to reduce induced noise
1 year 6 months ago #325548 by rodw
It depends on your machine amperage. No scaling resistors are rwquired. Most people use 20:1 which gives a 200 volt full scale, 125 amps might be better at 30:1. (300 volts)
The thing is that the THCAD is rated for overvoltage of 500 volts. The voltage will only go over 200 volts on piercing when we do not care about the voltage then. During cutting voltage is between 100-170 volts. Keeping the max voltage range low means the readings are more accurate as more of the ADC's range is used. 50:1 is popular with a lot of non-linuxcnc THC's  (probably with a 0-5 volt ADC). That would be better for a THCAD5.
1 year 6 months ago #325551 by snowgoer540
Short answer:
My Powermax is paired with a THCAD-10.  I changed it to 20:1.  It’s served me well with no issues over the years.
Long answer:
forum.linuxcnc.org/plasmac/39999-thcad-1...powermax45-xp#181612
1 year 6 months ago #325628 by grijalvap
I Agree with you regarding the Optimisation of the dynamic range (headroom) of the AD converter.
will double check all the machines most of them are hyperterm 85, 105,125 and maxpro 250.
so I need to check max voltage and select the proper divide ratio
1 year 6 months ago #325739 by tommylight
25:1 :)
20:1 or 30:1 as i fully agree with Rod and Snowwy, it gives a better working range, although it will be very hard to actually see any difference in normal use, but might be noticeable at very high feed rates as it would track better the surface of the material. Never actually tried to notice as no plans for it, it works and it works very good.
Time to create page: 0.323 seconds
