Problem with THC
1 year 6 months ago - 1 year 6 months ago #326248 by mariusl
Problem with THC was created by mariusl
I have a machine that has a Hypertherm 105 Sync source on and I am having issues getting the THC to work correctly.
I had to adjust the THC_delay to 5 seconds before I could get a stable voltage reading for Autovolts. The torch will go down to the cut height but starts moving upwards before the THC_delay has timed out. The cut voltage seems to settle at 55V but the torch moves up until it reaches 75V and stays there.
The strange thing is it will cut the first cut correct and then misbehaves after that.
Any ideas where to fiddle?
Regards
Marius
www.bluearccnc.com
Last edit: 1 year 6 months ago by mariusl.
1 year 6 months ago #326252 by tommylight
Replied by tommylight on topic Problem with THC
Use halscope to do a plot of encoder.0.velocity pin during a pierce, might be interference, although as you are getting 55 and 75V readings it also seems not right, and this might be due to scaling and/or due to interference.
What divider ratio is Mesa THCAD set to? Usually 1/32.
If this is a new machine, disable auto volts, disable void lock and velocity lock, well disable everything automated until you get the machine working correctly, only then enable the automation.
1 year 6 months ago #326256 by mariusl
Replied by mariusl on topic Problem with THC
It is a new machine. The divider is set to 1/32. I am not sure what voltage is given by the source as this is also a new configuration Hypertherm that does stuff automatically. It reads the consumable and does it's own adjustments. Although I disabled that feature on the plasma source. It might still be doing something that I am not aware off.
The voltage seems very stable . The thing that bothers me is that the torch starts moving up as soon as it starts cutting. It does not delay the 5 seconds that I set the THC_delay to.
Regards
Marius
www.bluearccnc.com
1 year 6 months ago #326259 by rodw
Replied by rodw on topic Problem with THC
You need to plot the voltage or encoder with halscope. I think that is way too low. I would expect around 130 volts. I suspect the THCAD is not properly calibrated. The plot will tell you how long to delay. I would check the input voltage at the thcad with a multimeter.
I did have a machine once that needed about 2 seconds to be stable...
1 year 6 months ago #326265 by mariusl
I use this calculator to calculate the parameters for the THC.
jscalc.io/source/ScVgoteuXJ9ySlXo
Can you check to see if it is accurate please?
Regards
Marius
www.bluearccnc.com
1 year 6 months ago #326275 by mariusl
How do others determine the volt/mm if you don't use Autovolt?
Regards
Marius
www.bluearccnc.com
Time to create page: 0.371 seconds
