Zero Pierce delay After pierce Only
- grijalvap
- Thank you received: 63
30 Apr 2025 09:49 - 30 Apr 2025 09:55 #327350
by grijalvap
Zero Pierce delay After pierce Only was created by grijalvap
Hi, yesterday I used the Pierce only funtion in 1 inch plate, it worked very well, I saw the inconvenient of having to edit the file to change pierce delay to 0.0 after pierce only.
I wonder if we can have a control to override the pierce delay vaule and make it zero, maybe the same button that changes from Normal Cut to Pierce Only can has the funtions Normal Cut - Pierce Only - After Pierce.
Last edit: 30 Apr 2025 09:55 by grijalvap.
- Hakan
- Thank you received: 497
30 Apr 2025 11:57 - 30 Apr 2025 11:57 #327371
by Hakan
Replied by Hakan on topic Zero Pierce delay After pierce Only
I use a separate material config for piercing and switch to normal when cutting.
Going a bit further, one could have automatic shift to a piercing-only material config when doing piercing only.
And shift back afterwards.
Last edit: 30 Apr 2025 11:57 by Hakan.
- grijalvap
30 Apr 2025 12:50 #327372
by grijalvap
Replied by grijalvap on topic Zero Pierce delay After pierce Only
So basically if you select piercing only
1-Make piercing.
2- Ask the operator to clean dross.
3 - Ask the operators to change consumables (if the case).
4 - Start cutting with 0 piercing delay.
1-Make piercing.
- Thank you received: 7506
30 Apr 2025 16:20 #327388
Replied by tommylight on topic Zero Pierce delay After pierce Only
1. make piercing using another material config, for piercing only
2. ok
3. ok
4. start cutting with config for the material you are cutting.
2. ok
3. ok
- grijalvap
30 Apr 2025 16:39 #327389
by grijalvap
sorry I was no clear What yo mention is the actual process What I stated is the future state if the process can be modified we trying to avoid using 2 materials or 2 gCode files or edit the Gcode file to change PD to 0
- Thank you received: 4155
02 May 2025 17:30 #327567
Replied by rodw on topic Zero Pierce delay After pierce Only
When this feature was developed, the feeling was the pierce delay should still be used. Does it work for you if you try it?
02 May 2025 17:34 #327569
I forgot to mention Stefan (who's forum name escapes me ATM) was the chief tester on this and he cut countless full sheets of 16mm into small parts without needing to reset the pierce delay.When this feature was developed, the feeling was the pierce delay should still be used. Does it work for you if you try it?
- grijalvap
04 May 2025 18:13 #327718
by grijalvap
yes it works if you use 2 tools one with piercing delay and one with 0 delay.
I'm using the tool from sheetcam (tempoary tool created from file). so i need 2 files or edit the file after pierce and reload.
what I'm thinking is just press a button and make the Pircing delay 0,
- snowgoer540
- Thank you received: 907
04 May 2025 20:29 - 04 May 2025 20:31 #327726
by snowgoer540
Replied by snowgoer540 on topic Zero Pierce delay After pierce Only
You could just stop using temporary materials and let the materials in QtPlasmaC be your master.
Then you only have to perfect settings in one place. Furthermore for your situation you’d go to another tab, change the delay, do your pieces go back to the tab change the delay again and run the program. No editing gcode files necessary.
Temporary materials were meant to be temporary, QtPlasmaC and PlasmaC before were not built with a temporary materials workflow in mind.
Last edit: 04 May 2025 20:31 by snowgoer540.
04 May 2025 20:55 #327729
I absolutely and strictly use the materials in PlasmaC/QtPlasmaC, using anything else is asking for trouble.
I have modified the Inkscape gcodetools to output the required plasmac-feed-rate in gcode, and that was it.
Nothing more permanent than a temporary solution! Quote from someone on the internet...he/she was bloody right!Temporary materials were meant to be temporary, QtPlasmaC and PlasmaC before were not built with a temporary materials workflow in mind.
Time to create page: 0.439 seconds
