Zero Pierce delay After pierce Only
1 year 6 months ago - 1 year 6 months ago #327350 by grijalvap
Hi, yesterday I used the Pierce only funtion in  1 inch plate, it worked very well, I saw the inconvenient of having to edit the file to change pierce delay to 0.0 after pierce only.
I wonder if we can have a control to override the pierce delay vaule and make it zero, maybe the same button that changes from Normal Cut to Pierce Only can has the funtions Normal Cut - Pierce Only - After Pierce.
Last edit: 1 year 6 months ago by grijalvap.
1 year 6 months ago - 1 year 6 months ago #327371 by Hakan
I use a separate material config for piercing and switch to normal when cutting.
Going a bit further, one could have automatic shift to a piercing-only material config when doing piercing only.
And shift back afterwards.
Last edit: 1 year 6 months ago by Hakan.
1 year 6 months ago #327372 by grijalvap
So basically if you select piercing only
1-Make  piercing.
2- Ask the operator to clean dross.
3 - Ask the operators to change consumables (if the case).
4 - Start cutting with 0 piercing delay.
1 year 6 months ago #327388 by tommylight
1. make piercing using another material config, for piercing only
2. ok
3. ok
4. start cutting with config for the material you are cutting.
1 year 6 months ago #327389 by grijalvap
sorry I was no clear What yo mention is the actual process What I stated is the future state if the process can be modified we trying to avoid using 2 materials or 2 gCode files or edit the Gcode file to change PD to 0
1 year 5 months ago #327567 by rodw
When this feature was developed, the feeling was the pierce delay should still be used. Does it work for you if you try it?
Time to create page: 0.058 seconds
