- Thank you received: 4153
I forgot to mention Stefan (who's forum name escapes me ATM) was the chief tester on this and he cut countless full sheets of 16mm into small parts without needing to reset the pierce delay.When this feature was developed, the feeling was the pierce delay should still be used. Does it work for you if you try it?
Nothing more permanent than a temporary solution! Quote from someone on the internet...he/she was bloody right!Temporary materials were meant to be temporary, QtPlasmaC and PlasmaC before were not built with a temporary materials workflow in mind.
In the Sheetcam processor, there are some variables at the top of the file to select between Sheetcam and qtplasmac tools. Sorry about that but had to humor Les at Sheetcam seeing its distributed with his software (and he wrote the post.)!yes it works if you use 2 tools one with piercing delay and one with 0 delay.
I'm using the tool from sheetcam (tempoary tool created from file). so i need 2 files or edit the file after pierce and reload.
what I'm thinking is just press a button and make the Pircing delay 0,
