QTPlasmac pierce delay handling
- kworm
- Thank you received: 16
06 Jun 2025 21:50 #329859
by kworm
QTPlasmac pierce delay handling was created by kworm
I just got QTPlasmac (2.10 using buildbot instructions) going and starting to make some test cuts. My plasma cutter (Thermal Dynamics Cutmaster 60i) has a ~2 second delay for gas purge before the pilot starts. That means I have to add whatever actual pierce delay I need to the two seconds making it, for example, something like 2.5 seconds. After the cut is made there is post flow for 20 seconds and if you start a cut while post flow is active there is no delay and the pilot lights immediately making the pierce delay too long. When the post flow stops after 20 seconds then the 2 second delay is back. I know I could have two different materials... one for first cut and one for additional cuts and have my Fusion 360 post processor change materials but that seems like a bit of a hack. Is there a way I could handle this in hal/script/component?
- Thank you received: 7506
07 Jun 2025 03:37 #329868
Replied by tommylight on topic QTPlasmac pierce delay handling
Is ARCOK signal wired to plasma or derived from THCAD?
- kworm
07 Jun 2025 08:05 #329877
by kworm
Replied by kworm on topic QTPlasmac pierce delay handling
ARCOK is derived from THCAD. My unit has arc ok output but the relay on the inverter board is not working so I'm using mode 0 for now. ark-ok-low is 60 and ark-ok-high is 200. Pilot voltage seems to be around 157 so maybe I could set ark-ok-high to 145 or 150. I've been testing on a scrap piece of 1/2" I had so not sure if the pilot voltage changes based on material thickness.
07 Jun 2025 09:07 #329880
See what voltage you get when cutting and how much it fluctuates, then set the ARC low and high to about 20-30V above and below.
Do a lot of tests till you get it to have cuts without interruption and no false OK signal at start.
And yes, the voltage will differ with thickness and feed rate, but usually under 10V difference on all of my machines (over 15 machines) for materials from 1.8mm to 6mm.
The following user(s) said Thank You: kworm
- Thank you received: 4155
07 Jun 2025 15:54 #329896
Replied by rodw on topic QTPlasmac pierce delay handling
The pierce delay starts from when qtplasmac gets an ArcOK signal signifying that arc transfer has occurred. If your synthesized arcOK is off, you will have problems.
Do yourself a favour and wire in the machine's arcOK signal. The time you will save stuffing around trying to get a synthesized arcOK working will more than cover the time you will spend wiring it in properly.
- kworm
07 Jun 2025 19:07 #329911
by kworm
Unfortunately the relay in the unit is damaged and does not close. I ran through the diagnostics in the service manual to come to that conclusion and of course the service manual recommendation is to replace the inverter board which is half the cost of a new unit lol. It's also very difficult to access but some point down the road I will pull it apart and replace the relay on the board if possible. I'm going to try Tommy's suggestions and hopefully that will buy some time until I fix it or sell it and get another unit.
07 Jun 2025 19:14 #329912
07 Jun 2025 19:36 #329914
the most likely cause of a "damaged" relay is oxidisation because the current through the relay has been below the minimum operating spec. Installing a HS10 1 K pulldown resistor is likely to fix the issue after a few operations once the oxide is burnt off. This is covered in the qtplasmac docs.Unfortunately the relay in the unit is damaged and does not close. I ran through the diagnostics in the service manual to come to that conclusion and of course the service manual recommendation is to replace the inverter board which is half the cost of a new unit lol. It's also very difficult to access but some point down the road I will pull it apart and replace the relay on the board if possible. I'm going to try Tommy's suggestions and hopefully that will buy some time until I fix it or sell it and get another unit.
- snowgoer540
- Thank you received: 907
07 Jun 2025 19:41 #329915
by snowgoer540
Replied by snowgoer540 on topic QTPlasmac pierce delay handling
Aforementioned docs references:
Reed relay:
linuxcnc.org/docs/devel/html/plasma/qtpl...l#plasma:reed-arc-ok
Contact loading schematic:
linuxcnc.org/docs/devel/html/plasma/qtpl...tact-load-schematics
Calculations:
linuxcnc.org/docs/devel/html/plasma/qtpl...asma:qt-contact-load
Reed relay:
Calculations:
The following user(s) said Thank You: tommylight, kworm
- kworm
08 Jun 2025 06:05 #329937
by kworm
Thanks everyone. I'll give the resistor a try even though the unit fails the manufacturers test. If that doesn't work I'll use a reed relay until I fix or sell it.
Time to create page: 0.151 seconds
