QTplasmac material database enhancement
04 Jul 2025 14:39 #331241 by kworm
I cut a lot of thicker material that needs a ramp pierce.  I am thinking of adding ramp pierce parameters to the material database along with adding ramp pierce to the conversational area of QTplasmac.   My purpose for this would be to keep all the cut info in one place and to be able to use the conversational on thicker parts vs having to CAM simple things.   Just thought I would see if there was interest in this from others and/or other thoughts on it.
22 Jul 2025 06:57 #332163 by rodw
Replied by rodw on topic QTplasmac material database enhancement
Have a look at monokrom. it might do this already as the designer did the ramp piercing and pushed to qtp. It has a proper SQL database
The following user(s) said Thank You: kworm
