Plasmac to Qtplasmac conversion not working
- Esaber
- Thank you received: 16
20 Jul 2025 09:23 #332050
by Esaber
Plasmac to Qtplasmac conversion not working was created by Esaber
Hi guys. My migrated qtplasmac config (from plasmac) is not working as expected. The conversion ends with auccess but when I launch qtp both estop and power buttons are inactive, i.e clicking them does not do anything. The same buttons work fine in Axis. My setup uses the estop button (F1 keyboard button) in Axis to latch a relay and power on the plasma table central power unit and the F2 keyboard button to enable the Axis interface. Both axis and qtp contain the same lines for estop-out and machine enable. I set estop mode to 2 (button) but I still get no sign of life when pressing the estop button. I have a physical estop button which is not connected to linuxcnc. It does cut off the plasma machine when activated. I will post the ini file for review.
- Esaber
20 Jul 2025 10:05 - 20 Jul 2025 10:13 #332051
by Esaber
Replied by Esaber on topic Plasmac to Qtplasmac conversion not working
hal file content:
# Generated by PNCconf at Thu Feb 14 05:38:27 2019
# Using LinuxCNC version: 2.8
# overwritten when you run PNCconf again
loadrt [KINS]KINEMATICS
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_spindles=[TRAJ]SPINDLES
loadrt hostmot2
loadrt hm2_pci config="num_encoders=6 num_pwmgens=0 num_stepgens=5 sserial_port_0=00000x"
setp hm2_5i25.0.watchdog.timeout_ns 5000000
loadrt pid names=pid.x,pid.y,pid.z,pid.s
addf hm2_5i25.0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf pid.s.do-pid-calcs servo-thread
addf hm2_5i25.0.write servo-thread
# external output signals
# --- MACHINE-IS-ENABLED ---
net machine-is-enabled => hm2_5i25.0.7i77.0.0.output-02
# --- ESTOP-OUT ---
net estop-out => hm2_5i25.0.7i77.0.0.output-03
# external input signals
# --- BOTH-HOME-X ---
net both-home-x <= hm2_5i25.0.7i77.0.0.input-01
# --- BOTH-HOME-Y ---
net both-home-y <= hm2_5i25.0.7i77.0.0.input-02
# --- BOTH-HOME-Z ---
net max-home-z <= hm2_5i25.0.7i77.0.0.input-03-not
# AXIS X JOINT 0
setp pid.x.Pgain [JOINT_0]P
setp pid.x.Igain [JOINT_0]I
setp pid.x.Dgain [JOINT_0]D
setp pid.x.bias [JOINT_0]BIAS
setp pid.x.FF0 [JOINT_0]FF0
setp pid.x.FF1 [JOINT_0]FF1
setp pid.x.FF2 [JOINT_0]FF2
setp pid.x.deadband [JOINT_0]DEADBAND
setp pid.x.maxoutput [JOINT_0]MAX_OUTPUT
setp pid.x.error-previous-target true
net x-index-enable => pid.x.index-enable
net x-enable => pid.x.enable
net x-pos-cmd => pid.x.command
net x-pos-fb => pid.x.feedback
net x-output <= pid.x.output
# ---PWM Generator signals/setup---
setp hm2_5i25.0.7i77.0.1.analogout0-scalemax [JOINT_0]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout0-minlim [JOINT_0]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout0-maxlim [JOINT_0]OUTPUT_MAX_LIMIT
net x-output => hm2_5i25.0.7i77.0.1.analogout0
net x-pos-cmd <= joint.0.motor-pos-cmd
net x-enable <= joint.0.amp-enable-out
# enable _all_ sserial pwmgens
net x-enable => hm2_5i25.0.7i77.0.1.analogena
setp hm2_5i25.0.encoder.00.counter-mode 0
setp hm2_5i25.0.encoder.00.filter 1
setp hm2_5i25.0.encoder.00.index-invert 0
setp hm2_5i25.0.encoder.00.index-mask 0
setp hm2_5i25.0.encoder.00.index-mask-invert 0
setp hm2_5i25.0.encoder.00.scale [JOINT_0]ENCODER_SCALE
net x-pos-fb <= hm2_5i25.0.encoder.00.position
net x-vel-fb <= hm2_5i25.0.encoder.00.velocity
net x-pos-fb => joint.0.motor-pos-fb
net x-index-enable joint.0.index-enable <=> hm2_5i25.0.encoder.00.index-enable
net x-pos-rawcounts <= hm2_5i25.0.encoder.00.rawcounts
# ---setup home / limit switch signals---
net both-home-x => joint.0.home-sw-in
net both-home-x => joint.0.neg-lim-sw-in
net both-home-x => joint.0.pos-lim-sw-in
# AXIS Y JOINT 1
setp pid.y.Pgain [JOINT_1]P
setp pid.y.Igain [JOINT_1]I
setp pid.y.Dgain [JOINT_1]D
setp pid.y.bias [JOINT_1]BIAS
setp pid.y.FF0 [JOINT_1]FF0
setp pid.y.FF1 [JOINT_1]FF1
setp pid.y.FF2 [JOINT_1]FF2
setp pid.y.deadband [JOINT_1]DEADBAND
setp pid.y.maxoutput [JOINT_1]MAX_OUTPUT
setp pid.y.error-previous-target true
net y-index-enable => pid.y.index-enable
net y-enable => pid.y.enable
net y-pos-cmd => pid.y.command
net y-pos-fb => pid.y.feedback
net y-output <= pid.y.output
setp hm2_5i25.0.7i77.0.1.analogout1-scalemax [JOINT_1]OUTPUT_SCALE
setp hm2_5i25.0.7i77.0.1.analogout1-minlim [JOINT_1]OUTPUT_MIN_LIMIT
setp hm2_5i25.0.7i77.0.1.analogout1-maxlim [JOINT_1]OUTPUT_MAX_LIMIT
net y-output => hm2_5i25.0.7i77.0.1.analogout1
net y-pos-cmd <= joint.1.motor-pos-cmd
net y-enable <= joint.1.amp-enable-out
setp hm2_5i25.0.encoder.01.counter-mode 0
setp hm2_5i25.0.encoder.01.filter 1
setp hm2_5i25.0.encoder.01.index-invert 0
setp hm2_5i25.0.encoder.01.index-mask 0
setp hm2_5i25.0.encoder.01.index-mask-invert 0
setp hm2_5i25.0.encoder.01.scale [JOINT_1]ENCODER_SCALE
net y-pos-fb <= hm2_5i25.0.encoder.01.position
net y-vel-fb <= hm2_5i25.0.encoder.01.velocity
net y-pos-fb => joint.1.motor-pos-fb
net y-index-enable joint.1.index-enable <=> hm2_5i25.0.encoder.01.index-enable
net y-pos-rawcounts <= hm2_5i25.0.encoder.01.rawcounts
net both-home-y => joint.1.home-sw-in
net both-home-y => joint.1.neg-lim-sw-in
net both-home-y => joint.1.pos-lim-sw-in
# AXIS Z JOINT 2
setp pid.z.Pgain [JOINT_2]P
setp pid.z.Igain [JOINT_2]I
setp pid.z.Dgain [JOINT_2]D
setp pid.z.bias [JOINT_2]BIAS
setp pid.z.FF0 [JOINT_2]FF0
setp pid.z.FF1 [JOINT_2]FF1
setp pid.z.FF2 [JOINT_2]FF2
setp pid.z.deadband [JOINT_2]DEADBAND
setp pid.z.maxoutput [JOINT_2]MAX_OUTPUT
setp pid.z.error-previous-target true
# This setting is to limit bogus stepgen
# velocity corrections caused by position
# feedback sample time jitter.
setp pid.z.maxerror 0.012700
net z-index-enable => pid.z.index-enable
net z-enable => pid.z.enable
net z-pos-cmd => pid.z.command
net z-pos-fb => pid.z.feedback
net z-output <= pid.z.output
# Step Gen signals/setup
setp hm2_5i25.0.stepgen.00.dirsetup [JOINT_2]DIRSETUP
setp hm2_5i25.0.stepgen.00.dirhold [JOINT_2]DIRHOLD
setp hm2_5i25.0.stepgen.00.steplen [JOINT_2]STEPLEN
setp hm2_5i25.0.stepgen.00.stepspace [JOINT_2]STEPSPACE
setp hm2_5i25.0.stepgen.00.position-scale [JOINT_2]STEP_SCALE
setp hm2_5i25.0.stepgen.00.step_type 0
setp hm2_5i25.0.stepgen.00.control-type 1
setp hm2_5i25.0.stepgen.00.maxaccel [JOINT_2]STEPGEN_MAXACCEL
setp hm2_5i25.0.stepgen.00.maxvel [JOINT_2]STEPGEN_MAXVEL
# ---closedloop stepper signals---
net z-pos-cmd <= joint.2.motor-pos-cmd
net z-vel-cmd <= joint.2.vel-cmd
net z-output => hm2_5i25.0.stepgen.00.velocity-cmd
net z-pos-fb <= hm2_5i25.0.stepgen.00.position-fb
net z-pos-fb => joint.2.motor-pos-fb
net z-enable <= joint.2.amp-enable-out
net z-enable => hm2_5i25.0.stepgen.00.enable
net max-home-z => joint.2.home-sw-in
net z-neg-limit => joint.2.neg-lim-sw-in
net max-home-z => joint.2.pos-lim-sw-in
# # SPINDLE
# setp pid.s.Pgain [SPINDLE_0]P
# setp pid.s.Igain [SPINDLE_0]I
# setp pid.s.Dgain [SPINDLE_0]D
# setp pid.s.bias [SPINDLE_0]BIAS
# setp pid.s.FF0 [SPINDLE_0]FF0
# setp pid.s.FF1 [SPINDLE_0]FF1
# setp pid.s.FF2 [SPINDLE_0]FF2
# setp pid.s.deadband [SPINDLE_0]DEADBAND
# setp pid.s.maxoutput [SPINDLE_0]MAX_OUTPUT
setp pid.s.error-previous-target true
# net spindle-index-enable => pid.s.index-enable
# net spindle-enable => pid.s.enable
# net spindle-vel-cmd-rpm => pid.s.command
# net spindle-vel-fb-rpm => pid.s.feedback
# net spindle-output <= pid.s.output
# # ---setup spindle control signals---
# net spindle-vel-cmd-rps <= spindle.0.speed-out-rps
# net spindle-vel-cmd-rps-abs <= spindle.0.speed-out-rps-abs
# net spindle-vel-cmd-rpm <= spindle.0.speed-out
# net spindle-vel-cmd-rpm-abs <= spindle.0.speed-out-abs
# net spindle-enable <= spindle.0.on
# net spindle-cw <= spindle.0.forward
# net spindle-ccw <= spindle.0.reverse
# net spindle-brake <= spindle.0.brake
# net spindle-revs => spindle.0.revs
# net spindle-at-speed => spindle.0.at-speed
# net spindle-vel-fb-rps => spindle.0.speed-in
# net spindle-index-enable <=> spindle.0.index-enable
# # ---Setup spindle at speed signals---
# sets spindle-at-speed true
# connect miscellaneous signals
# ---HALUI signals---
net axis-select-x halui.axis.x.select
net jog-x-pos halui.axis.x.plus
net jog-x-neg halui.axis.x.minus
net jog-x-analog halui.axis.x.analog
net x-is-homed halui.joint.0.is-homed
net axis-select-y halui.axis.y.select
net jog-y-pos halui.axis.y.plus
net jog-y-neg halui.axis.y.minus
net jog-y-analog halui.axis.y.analog
net y-is-homed halui.joint.1.is-homed
net axis-select-z halui.axis.z.select
net jog-z-pos halui.axis.z.plus
net jog-z-neg halui.axis.z.minus
net jog-z-analog halui.axis.z.analog
net z-is-homed halui.joint.2.is-homed
net jog-selected-pos halui.axis.selected.plus
net jog-selected-neg halui.axis.selected.minus
# net spindle-manual-cw halui.spindle.0.forward
# net spindle-manual-ccw halui.spindle.0.reverse
# net spindle-manual-stop halui.spindle.0.stop
# net machine-is-on halui.machine.is-on
net jog-speed halui.axis.jog-speed
net MDI-mode halui.mode.is-mdi
# ---coolant signals---
net coolant-mist <= iocontrol.0.coolant-mist
net coolant-flood <= iocontrol.0.coolant-flood
# ---probe signal---
net probe-in => motion.probe-input
# ---motion control signals---
net in-position <= motion.in-position
net machine-is-enabled <= motion.motion-enabled
# ---digital in / out signals---
# ---estop signals---
net estop-out => iocontrol.0.emc-enable-in
# ---manual tool change signals---
# loadusr -W hal_manualtoolchange
# net tool-change-request iocontrol.0.tool-change => hal_manualtoolchange.change
# net tool-change-confirmed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
# net tool-number iocontrol.0.tool-prep-number => hal_manualtoolchange.number
# net tool-prepare-loopback iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
# toolchange passthrough
net tool:change iocontrol.0.tool-change => iocontrol.0.tool-changed
net tool:prep iocontrol.0.tool-prepare => iocontrol.0.tool-prepared
# Added By me 08.12.2024
# Mesa Codes
setp hm2_5i25.0.encoder.02.scale -1
setp hm2_5i25.0.encoder.02.filter 1
setp hm2_5i25.0.encoder.02.counter-mode 1
loadrt hostmot2
# --- ESTOP-OUT ---
# AXIS X JOINT 0
# AXIS Y JOINT 1
# AXIS Z JOINT 2
# # SPINDLE
# Mesa Codes
Last edit: 20 Jul 2025 10:13 by Esaber.
- Esaber
20 Jul 2025 10:15 - 20 Jul 2025 10:59 #332052
by Esaber
In the Axis software:
this line latches the power relay to power up the esab machine (F1)
and this line enables the Axis interface (F2)
Last edit: 20 Jul 2025 10:59 by Esaber.
- snowgoer540
- Thank you received: 906
20 Jul 2025 15:17 #332064
by snowgoer540
Replied by snowgoer540 on topic Plasmac to Qtplasmac conversion not working
You haven’t stated if you’re trying to use 2.9 or 2.10, but either way, my recommendation is to just run pncconf and make a new config.
So much has changed from when the conversion script was made, and it was really a stop gap when QtPlasmaC first came out that wasn’t fully maintained.
- Esaber
20 Jul 2025 23:37 #332091
by Esaber
I’m using the latest versiin of linuxcnc. I tried a new config before posting but got an error when launching qtplasmac. I will try again and post the error here. Thanks.
Time to create page: 0.319 seconds
