- Thank you received: 153
Yes, this is preferred in my book. You want to know the torch height and the voltage quoted in cut charts may not be correct due to worn/eroded electrodes etc so its far better to sample the torch voltage once the voltage has stabilised and keep that constant. There is a very high correlation between torch voltage and torch height so its an excellent process control variable. This is covered in the Plasma Primer in the docs.Yes - unchecking autovolts then uses the material voltage. Duh
thanks again
sam
