Acr ok/Up/Down not working
- Kempinger
05 Aug 2025 22:35 - 05 Aug 2025 22:35 #332931
by Kempinger
Acr ok/Up/Down not working was created by Kempinger
Hi guys,
I'm having some troble with my Plasmac setup: Signals for Up/Down/Arc do not show up in GUI, in HAL monitor pins from mesa 7i96s act like they should (Proma THC Compact set to Test mode). No response for "Virtual LEDs" in GUI. Tried idle and also duringe a simulated cutting operation.
Float-Switch works perfectly, also axis movement. Machine was configured using pncconf wizzard, set to mode 2.
Thanks for any information!
Last edit: 05 Aug 2025 22:35 by Kempinger.
- Thank you received: 7478
05 Aug 2025 23:50 #332932
Replied by tommylight on topic Acr ok/Up/Down not working
This was way back so no idea if this got fixed or not, but this did not work for some very strange reason as it is a must when setting up such a system.
You can try running a cut or two with the torch off, see if that activates the LED's.
You can also use hal show to watch the input pins and check if they are correctly set in hal, the do some actual cuts.
The following user(s) said Thank You: Kempinger
- snowgoer540
- Thank you received: 906
06 Aug 2025 01:29 #332935
by snowgoer540
Replied by snowgoer540 on topic Acr ok/Up/Down not working
The inputs below are only valid while cutting as mentioned in
this table
The reason is because while the inputs are from an external source, the PlasmaC component still takes the following into consideration before making torch height corrections:
THC enabled?
Torch on (meaning the component is actually commanding the plasmac.torch-on output TRUE)?
Ignore Arc OK enabled?
Mesh Mode enabled?
Velocity anti-dive (cornerlock) enabled and are you below the anti-dive velocity?
Did we reach a top or bottom limit?
If you are curious, the pertinent Mode 2 code controlling all of this is here . The GUI indicators only turn on when led_down or led_up are TRUE (assuming the correct HAL connections are made between the component and the GUI, of course).
I think you did the pertinent test by seeing that the appropriate HAL pins light up in halshow, and ensuring the correct HAL connections have been made. I dont know what you mean by a simulated cut, but if the torch was not on (plasmac.torch-on TRUE), then it would not have worked.
I am not sure I would call it strange, but you'll have to make some actual test cuts to see the indicators light up.
plasmac.move-up
plasmac.move-downThe reason is because while the inputs are from an external source, the PlasmaC component still takes the following into consideration before making torch height corrections:
THC enabled?
Mesh Mode enabled?
The following user(s) said Thank You: tommylight, Kempinger
- Kempinger
06 Aug 2025 08:59 #332947
by Kempinger
Replied by Kempinger on topic Acr ok/Up/Down not working
Thank you guys!
I don't know why but now it's working. I have not made any changes in the configuration, just re-starting the wizzard and toggeling the modes several times. Strange.
Really nice GUI!
Really nice GUI!
