Laser Button Doesn't toggle to mark edge and origin
- wels
24 Oct 2025 14:50 - 24 Oct 2025 15:02 #337063
by wels
Laser Button Doesn't toggle to mark edge and origin was created by wels
I am Trying to set up a laser to align the work to the sheet in QTPlasmaC, however, it does not appear to be working properly. In the owners manual it says it should change to mark edge and then mark origin. it just changes to show it is turned on. What am I missing?
Last edit: 24 Oct 2025 15:02 by wels. Reason: missed info
- wels
24 Oct 2025 14:54 #337066
by wels
Replied by wels on topic Laser Button Doesn't toggle to mark edge and origin
I forgot to mention that this is in QTPlasmaC
- snowgoer540
- Thank you received: 906
24 Oct 2025 15:11 #337067
by snowgoer540
Replied by snowgoer540 on topic Laser Button Doesn't toggle to mark edge and origin
Did you make a custom user button for your Laser, or are you using the LASER button in the DRO box?
- wels
24 Oct 2025 15:13 #337068
by wels
Is the DRO box the buttons added in settings, then yes. I just found that I need hal pin
qtplasmac.ext_laser_touchoff
I have to figure out where to put it and if it will work...
- snowgoer540
24 Oct 2025 15:17 #337069
by snowgoer540
I am going to assume you made a custom button for your laser. The LASER button in the DRO box is not shown until a offset is set, I reckon the user manual does not explicitly say that. I'll mark it down to add it to the docs later.
Assuming you made the correct HAL connections
You need to use the peripheral offsets section to set the offset between the torch and the laser, and then the LASER button will appear.
The following user(s) said Thank You: wels
- snowgoer540
24 Oct 2025 15:20 #337071
by snowgoer540
That is not quite right. You just need to finish the following hal connection in either the <machine_name>.hal file or the <machine_name>_connections.hal file, I cant remember where it is off the top of my head.
Then do the peripheral offsets part and the LASER button will show.
# --- PLASMAC:LASER-ON ---
net plasmac:laser-on => YOUR_OUTPUT_PINThen do the peripheral offsets part and the LASER button will show.
- wels
24 Oct 2025 15:21 #337072
by wels
That works! thanks for that little bit of advise. I could have saved myself the headache by asking right away.
- snowgoer540
24 Oct 2025 15:29 #337073
by snowgoer540
Glad to help. The user guide maybe needs a little clarification in this area. It's sometimes difficult to write user guides when you already know the process...
Happy cutting.
Happy cutting.
- snowgoer540
02 Nov 2025 17:11 #337723
by snowgoer540
To close the loop here, this commit (to the Master branch) clarifies when the LASER and CAMERA buttons become visible:
github.com/LinuxCNC/linuxcnc/commit/ce1e...442d1e9b634e2eb8c5a7
Time to create page: 0.123 seconds
