USB activity causes network error
1 year 5 days ago #337301 by mariusl
I have seen the following issue occur on three machines that Range from 2.9.3 to 2.9.6.
The hardware is all cases are Lenovo i5 mini PC's running MX Linux 23.x Bookworm. The WiFi dongle is a USB type
What seems to happen is that when there is USB activity the network to the Mesa 7i96S will get a read error. It means that the network message could not be compete in one cycle. It typically happens when the USB stick is removed or inserted, especially if the machine is busy executing a program. It will also happen if the WiFi is active like when a file is uploaded to the nc_files directory from a laptop on the network.
Is there anyone else that has maybe seen this or know of a solution?
Regards
Marius
www.bluearccnc.com
1 year 5 days ago #337310 by tommylight
How is the network for Mesa card set up, using network manager or by editing the /etc/network/interfaces file?
1 year 5 days ago - 1 year 5 days ago #337312 by PCW
Also what USB dongle?
I have a rtl8192cu based USB WIFI dongle on this test machine
and it seem to have no effect on latency when plugged/unplugged
Have you done the usual optimizations?
DKMS driver for RealTek Ethernet chips
Turn off IRQ coalescing on Intel Ethernet chips
in grub file isolcpus = last processor
pin Ethernet IRQ to last processor
Actually it's worse than that, with default settings, it means 5 read requests in a row timed out
so usually means multi-ms latency...
Last edit: 1 year 5 days ago by PCW.
1 year 2 days ago #337567 by mariusl
Tommy I usually make use of nmtui or the network manager
Regards
Marius
www.bluearccnc.com
1 year 2 days ago #337568 by mariusl
I use the TP=Link TL-WN823N WiFi dongle.
The Ethernet chip is Intel on the PC.
I have not turned of IRQ coalescing (don't know how)
I did isolcpus but I am not sure that I did it correctly. It has 4 processors.
Pin Ethernet IRQ to last processor - I have not heard about that so no I have not done that either.
Seem like I have a lot of things that could contribute to the problem
I did do latency tests on the PC's and they all seemed to perform very well with no noticable peaks at all
Regards
Marius
www.bluearccnc.com
1 year 1 day ago #337584 by tommylight
Is that the included Network Manager ?
If yes, then make sure the below is selected:
Time to create page: 0.066 seconds
