USB activity causes network error
1 year 1 day ago #337586 by mariusl
It is the included one yes. So you say I must select the option of "Use this connection ..."
Regards
Marius
www.bluearccnc.com
1 year 1 day ago #337587 by tommylight
The following user(s) said Thank You: mariusl
1 year 1 day ago #337592 by PCW
 You can check the irqmask ( and grub setup) with this script
File Name: checkmask_...0-31.txt
File Size:621 B
usage
first
chmod + checkmask,txt
then
./checkmask.txt  [ethernet_device_name]
You can pin  the Ethernet IRQ to the last processor with this script
File Name: pinirq_2025-10-31.txt
File Size:668 B
usage
first
chmod + pinirq,txt
then
sudo ./pinirq.txt  [ethernet_device_name]
To disable irq coalescing temporarily for testing:
sudo ethtool -C [ethernet_device_name]  rx-usecs 0
To permanently disable IRQ coalescing, you setup the RT ethernet interface in the interfaces file, something like:
auto eth0
iface eth0 inet static
address 10.10.10.1
hardware−irq−coalesce−rx−usecs 0
The following user(s) said Thank You: mariusl, rodw
1 year 6 hours ago #337661 by mariusl
Thanks Peter I will try all of the above.
Regards
Marius
www.bluearccnc.com
11 months 4 weeks ago - 11 months 4 weeks ago #337799 by mariusl
I got this result when I ran the checkmask file. I am sure that I don't know how to use isolcpu. I want to isolate two cores with last core being 7.  SO cores 6 and 7 to be used for linuxcnc.
Cores: 8
Actual CPU Mask: ff
Desired CPU Mask: 128
IRQ: 24
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1.0-40-rt-amd64 root=UUID=bfdcf9b0-7caa-4c4b-b4c3-585accea347a ro quiet isolcpus=2,7
Regards
Marius
www.bluearccnc.com
Last edit: 11 months 4 weeks ago by mariusl.
11 months 4 weeks ago #337805 by unknown
Some basics here
access.redhat.com/solutions/480473
Bit more detailed
rigtorp.se/low-latency-guide/
Your config isolates core 2 & 7.
I read a while back about isolating cores that were on the same die....has something to do with cahe and the like. I really wish I could recall that article.
Time to create page: 0.287 seconds
