QtPlasmaC – Magic Comments not creating materials from G-code
11 months 5 days ago - 11 months 5 days ago #339316 by MTTI
Hi everyone,I’m trying to use the Magic Comments in QtPlasmaC to automatically create/select materials from my G-code.
Example:
(o=2, nu=2, na=5mm Mild Steel 40A, ph=3.1, pd=0.1, ch=0.75, fr=3000, kw=1.0)
​​​​​​​Result:
- QtPlasmaC shows an error like “invalid parameter in magic comment”
- The material is not created automatically
Material management in the GUI works normally
My goal is to automatically load correct cut settings (pierce height, cut height, feed rate, etc.) from the G-code generated in my CAM software.
Questions:
- Any specific setting to enable this feature in the INI / QtPlasmaC preferences?
- Could someone share a working example G-code header with material Magic Comments?​​​​​​​
Thanks a lot in advance for your help!
Last edit: 11 months 5 days ago by MTTI.
11 months 5 days ago #339332 by snowgoer540
Can you post your actual gcode file?
What version of qtplasmac are you running? It’s in the header of the window.
There is a temporary example file for
both metric and imperial in the nc_files\plasmac folder…  here:
github.com/LinuxCNC/linuxcnc/blob/master...porary_materials.ngc
11 months 5 days ago #339337 by MTTI
Hi
This morning I was running v2.9-238.315 and later tested with v2.10-009.072. The issue was present on both versions.
I continued testing and the problem only occurs with o=1 and o=2 magic comments.
o=0 was always working correctly and did not cause any issue.
With o=1 and o=2, the material was written to the *_material.cfg* file, but QtPlasmaC showed a parameter error and did not update the material list. A restart of QtPlasmaC was required for the new material to appear.
I found the cause inside the function rewrite_material_file() in qtplasmac_gcode.
The code checks material_reload like this:
response = RUN(['halcmd', 'getp', self.matReloadPin], capture_output=True) if not int(response.stdout.decode()):     break
But on my installation, this command returns:
halcmd getp qtplasmac.material_reload = TRUE
Since TRUE cannot be converted to int(), a ValueError exception is raised.
This stops the reload process, which leads to the UI not updating and to the misleading “parameter missing” message.
I applied a workaround that accepts both 0/1 and TRUE/FALSE strings:
raw = response.stdout.decode().strip().upper() if raw in ['0', 'FALSE']:     break else:     continue
After this fix:
* o=1 and o=2 now correctly create or update materials
* the UI refreshes immediately
* no more incorrect popup message
* no restart of QtPlasmaC required
* o=0 continues to work as before
I also added a local improvement: after a new material is created, it is automatically selected as the current active material.
If needed, I can provide a clean patch and test G-code examples.
I am also available to run additional tests if required.
I have attached to this post the NGC file I have been using since this morning.
The temporary example file was not working either, except when using o=0
11 months 5 days ago #339354 by snowgoer540
Thank you for the help, I had narrowed it down to the rewrite_material_file method before I left for Thanksgiving dinner.  You definitely saved me time getting the rest of the way there.  From what I can tell without doing a bunch of digging, getp will return 'TRUE' or 'FALSE' when the halpin is setup as a 'bit'.
I pushed your fix for this to the master branch:   github.com/LinuxCNC/linuxcnc/commit/7333...d08fd2855851c8ee91b3
I also found a copy/paste bug and fixed that as well.
Thank you again!
11 months 5 days ago - 11 months 5 days ago #339356 by snowgoer540
I wanted to be sure ... HAL_BIT will always return 'TRUE' or 'FALSE':
getp evokes the function do_getp_cmd, and inside it calls data_value2 to format the response:
github.com/LinuxCNC/linuxcnc/blob/73337a...cmd_commands.cc#L883
here is where HAL_BIT goes to 'TRUE' or 'FALSE':
github.com/LinuxCNC/linuxcnc/blob/73337a...md_commands.cc#L2473
So checking for '0' is probably unnecessary, but it doesn't hurt either.
Last edit: 11 months 5 days ago by snowgoer540.
11 months 4 days ago #339370 by MTTI
I’m not a programmer (only a bit of Python, and some BASIC and C). It took me the whole day to find this issue, moving a debug print line around the code to locate where it was getting stuck.Thank you for the explanations, and also for pointing out the second copy/paste bug, I’ve fixed that one on my side as well.
Now I need to follow up with Pronest, as the post-processor still doesn’t insert commas between the parameters...
Regards
Time to create page: 0.133 seconds
