Qtplasmac- Auto Z axis movement not happening with thc proma 150
- Nathan40
- Topic Author
10 months 4 weeks ago #339725
by Nathan40
Qtplasmac- Auto Z axis movement not happening with thc proma 150 was created by Nathan40
Hi All,
I am using 7c81 board, raspi 5 with thc proma 150. I am using QTplasmaC
The gpios and leds for UP, DOWN, Arc OK are getting connected and blinking.
However, the Auto Z axis movement not happening with thc proma 150. Attaching the files for your reference. Please help.
10 months 4 weeks ago #339726
Replied by tommylight on topic Qtplasmac- Auto Z axis movement not happening with thc proma 150
What settings are on the Proma THC150 ?
- Nathan40
- Topic Author
10 months 4 weeks ago #339727
by Nathan40
Replied by Nathan40 on topic Qtplasmac- Auto Z axis movement not happening with thc proma 150
Voltage is set to 100 and H-t to 5.
10 months 4 weeks ago #339729
On the Proma, the first and second settings should be set at minimum, i do not recall what was the third and forth settings.
Only after having this work you can set voltage higher if it wobbles a lot while cutting.
- Nathan40
- Topic Author
10 months 3 weeks ago #339868
by Nathan40
hi,
The Z axis DRO will not move in spite of the following in Raspi 4/5:
a. torch on
b. THC enabled setting
c. HALSHOW is showing move up and even.
d. After trying the changed settings mentioned previously on proma.
e. Mode is 2 for the external THC
Please help as I have been trying to do the same for few weeks now and let me know if any settings need to be added in the HAL or ini.
# ---JOINT ASSOCIATED WITH THE Z AXIS---
net plasmac:axis-position joint.3.pos-fb => plasmac.axis-z-position
a. torch on
10 months 3 weeks ago #339869
Does the machine reach the requested speed while cutting?
If it does not, it will not turn height control on.
What are the settings on the Parameters page?
Set the VAD to 60% first and try again.
- Nathan40
- Topic Author
10 months 3 weeks ago - 10 months 3 weeks ago #339870
by Nathan40
hi
Machine reaches the requested speed while cutting. 1000
I have all the default settings on the Parameters Page.
Tried with VAD 60%. still does not work.
Also M3 $0 S1 does not work.
Last edit: 10 months 3 weeks ago by Nathan40.
- snowgoer540
- Thank you received: 907
10 months 3 weeks ago #339871
by snowgoer540
Replied by snowgoer540 on topic Qtplasmac- Auto Z axis movement not happening with thc proma 150
Can you upload a back of your configuration made from clicking BACKUP CONFIG on the settings tab inside of qtplasmac please?
- Nathan40
- Topic Author
10 months 3 weeks ago - 10 months 3 weeks ago #339906
by Nathan40
Thanks for your reply.
Please find attached my back up config.
Also I do not want G53 in my code when I load any .ngc file. Please help as I do not wish to install limit switches to my system. I want to use G31 instead before the cut starts with THC.
Time to create page: 0.114 seconds
