QTPLASMAC integrated cad/cam
8 months 1 week ago #343248 by tcbmetalworks
I ran sheet cam for a long time on my mach 3 plasma table. Maybe I am a little confused with qtplasmac its my first time using it. I just dont understand why you would have a materials tab and then end up setting all your speeds and feeds in sheet cam? Is this only for the conversational? Either way all in one would be much better. I am trying to keep it super simple so that I can teach people super easy how to run my machine. There also is no automatic nesting in sheet cam and I know this is not a easy task but, for a basic version should not be to crazy. This is what I have done so far, all internal to qtplasmac
8 months 1 week ago #343249 by tcbmetalworks
What is monokrom? Im happy to use pre-made tools would save me alot of effort.
8 months 1 week ago #343250 by Hakan
Replied by Hakan on topic QTPLASMAC integrated cad/cam
Good start!
Materials, there are two ways (at least). One is to set all options in Sheetcam and that overrides the settings from the Materials tab.
Sheetcam is then the master of everything. That's what you have seen.
An other way is to set material index from sheetcam, it uses then the material index from the Materials tab.
Still, you need to select that when you sit with Sheetcam.
For that you need to go in the post processor code and change to false line 24
useTool      = false  -- Set to true to use SheetCam's tool table to generate a temporary material file entry
An other way, that I use, is to set material myself when I am at the machine.
Sheetcam only makes the cutting movements, not the material selection.
For that, insert comments in the printouts on line 171 in the post processor
   else       post.Text ('; M190 P' , tool,' (',string.lower(toolName), ' material)\n')                   post.Text ('; M66 P3 L3 Q2 (wait for valid change)\n')             end
Note the initial ";" comment in the printout. Plus useTool=false.
Automatic nesting isn't needed, at least to start with.
Being able to read in several G-code objects and interactively
place them on a sheet would be golden.
I like your start and hope you continue.
8 months 1 week ago #343251 by tcbmetalworks
I will continue working on it everyday, I know theres a way I can make this work with multiple programs but it really makes it hard for me to train someone on it. a built in 2d cad would be amazing too, even if its just super simple. My goal is to have it be the MS paint of cad lol.
8 months 1 week ago #343252 by tcbmetalworks
One of the long term goals of the project, is to integrate it with AI I dont know if I will release this publicly or not as it will be to OP of a tool but If i do make it i will share it by pm to the members here. The idea is to be able to use ai to generate signs shapes parametric modeling, upload a photo and have it turn it into a silhouette, or design a cut file off of a text prompt, potentially a chat bot could also be implemented for diagnosis of the system. This same chat bot could be then implemented into a website and customers could very easily custom design there own signs etc, order them and we make them and ship them out.
The following user(s) said Thank You: NWE
8 months 5 days ago #343576 by tcbmetalworks
Here is two screen shots of the current state of the software, I am making it in python and will push it into the qtplasmac when its useable. im trying to keep it simple and easy/straight forward to learn/use. still is very buggy but am making progress. The goal is with the software is to bring the fabricator closer to the machine, its not to replace a real cad software just for drawing parts fast and easy. conversational cad.
Time to create page: 0.189 seconds
