Plasma table set, fine tuning a problem
7 months 2 weeks ago - 7 months 2 weeks ago #344407 by aikiaviator
Hi all, Firstly great crowd. Love your work.Ok so I have bult a table. Setup is as follows: 1.2mx1.2m cutting capability. Mesa 7i96 card. THCAD2 THC, Unimig Razorcut45 CNC enabled cutter.X Y, Y1, Z config. I have set the THCAD2 to 1:1 10v High status, and the Unimig at a 30:1 ratio, which should produce a roughly 5V at top end signal. I do not have any resistors in the mix.I have the cutter running but only WITHOUT THC. It cuts, BUT it does not do this nicely and I do not know how to best tune the system. I started on 5mm steel. (probably a little ambitious.). And I dont have enough knowledge on how to set the speeds, heights etc.. to get a clean cut before THC. Then I will need to solve THC. But thought best to get basic answer on settings for the 5mm first then the THC. So settings are as per the images below. I have not performed any other settings other than servo setups and max speeds. Unimig fires off, so Arc on/off work. Arc OK seems to be ok as when has no steel, it shuts off. THC yet to get working.
Last edit: 7 months 2 weeks ago by aikiaviator.
7 months 2 weeks ago #344410 by tommylight
-Set up the THC, any fine tuning without it is useless when THC is active
-25A for 5mm thick is way to low, roughly 10A/mm is OK
-with working THC, you need to fine tune air pressure (exclusively while the air is ON), voltage=cut height, feed rate
-cut quality will vary based on air moisture, material being cut, nozzle type and wear, so use new nozzle for fine tuning and after you have things working properly
7 months 2 weeks ago #344431 by Joco
 Not sure if you have a cut chart for that machine.  Have a look at this generic cut chart to get a sense of amps to use for a thickness. It will also give you a guide on speeds.  1.5mm cut height and 2.5 to 3mm pierce is pretty standard.
7 months 2 weeks ago #344495 by aikiaviator
Thanks Tommylight.
-Set up the THC, any fine tuning without it is useless when THC is active.
Ok. Will note
Yes this is already set to 40A in the 5mm profile
Ok. This I have definitely NOT looked at. Will do. Thanks.
I have a three stage Breathing Dryer rig from when painting, + a standard dryer, so dry air should not be a problem. But the rest of it I will need to work through. Thanks.
My main concern was the settings in the Configuration setting, specifically arc voltage setting etc... Any thoughts on this? Do you have some that you may be using?
7 months 2 weeks ago #344496 by aikiaviator
Hi yes, I have a cut chart for the cutter. BUT it does not specify a variable air pressure chat such as the one you have presented. So I think this could be useful. Thanks.
Separately, I was concerned about the configuration settings: mostly about the arc voltage etc... I read somewhere about a need to set the config of the THCAD2 into the settings of the Software based on a frequency... Cant remember where I saw that but the config setting are my main concern at the moment. The other thickness settings are in line with the cut charts for the machine.
That being said, I have literally never used a cutter, so have zero experience on how this should be set up. I live in Melb, AU. So if anyone local, would put on beers coffee or whatever for some localised help.  :)
7 months 2 weeks ago #344499 by rodw
The thcad is a voltage to frequency converter. It has individual calibration frequencies at 0 volts and max scale volts (10v or 5v) on a sticker on the board. you enter this data into the QTplasmac interface. Read the docs and  it is well explained.
Time to create page: 0.329 seconds
