Hi Rod, Thanks for the feedback. Unfortunately it does not have THCAD5, and this is what I am using. So calculator does not allow me to double check. It does have THCAD10 and THCAD300. So I have set to 10, and the Voltage scale is 1/2. So hopefully this makes sense. The setting I have are now: THCAD2: Low (i.e. Down) 5V, Frequency divider: 1/32. 0V 95.4, 5V 896.0. Gives me the following as set by pnconf: Voltage Scale 0.005996, Voltage Offset 2981.25. Plasma machine: Unimig Razorcut 45 CNC port is set to 30:1 ratio. I set the Plasma to 30:1 ration as a precaution. Do people think this is necessary, or would 20:1 be fine? It is a 45A plasma cutter.
